MAF sensor enlargment
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Has anyone ever tried to take a MAF sensor and cut the plastic away, placing the existing electronics into another (Larger) tube, and then re-assemble? Then, re-program to Accommodate for the extra Volume that you have added.
It should work, and I am thinking of trying it. If someone can tell me that it does not work no-way/no-how then I will re-think it. BUt I cannot forsee any problems, other than the car will run lean until you can reprogram... How lean it would runs willd depend on how large of a tube I have gone to.
It may be possible to roughly calculate the extra volume and be close enough that I should not throw a code...
For example the Dia of the OEM MAF is 2.5" (a guess here) and I go to a 3" tube. I can figure that the area of the original MAF was 4.908 sq inches, and the area of a 3" tube would be 7.068 sq inches. THerefore if I recalculated all of my MAF tables to 69% then it should be close enough to get off the ground and program from there...
Any thoughts or am I going frankenstein on it?
John
John
Car: An Ol Buick
Engine: Vsick
Re: MAF sensor enlargment
You might just mock up a little test rig. ie a scope, and gather up some MAFs, and see which one will report low air flows, best. You can improvise, using *channeling* tract, and then just blow thur a 1/4" hose, or something to restrict you lung capacity, and see what kind of results you get. Kind of a homemade Spirometer.... <G>
WOT, isn't that hard to get right, it's making a car that's fun to drive, that can take some time, and talent. If you're running a loose converter, and only going a 1/4m atta time, that makes life much easier.....
One other way to do things would be using one of the designs that used a *sampling tube*.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I thought Granatelli made a thirdgen MAF sensor, but I cant find it on their website or at Jegs anymore. What gives, did they discontinue it?
Car: 2000 BMW M5
Just how fast is your car that you need to do this? A stock MAF with some attention to the PE tables at high flows will be fine down into the 12s. Making your 8 bit MAF accomodate high flows is going to make the resolution worthless.
Not into the 12's thats for sure...
Iguess I was hoping for another .1 in the quarter by enlarging the MAF... It was worth a shot.
John
John
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
http://www.jegs.com/cgi-bin/ncommerc...73&prmenbr=361
there it is.
i have one, not sure how to use it in turn with tuning my chip.
on the stock setting now, which flows better than stock w/out having to remove screens.
there it is.
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Do it man, modify that bugger! Post some pics too.
I've got one of the local shops here that is setting up a MAF calibration bench for the LS1 stuff, and I could probably put some of the L98 stuff on there to see how it does in modified trim.
John
John
Car: An Ol Buick
Engine: Vsick
Re: Re: MAF sensor enlargment
Originally posted by funstick
www.prosettech.com sells a tpi to ls1 ls6 lt1 maf translator. you have to email them however. i helped do the development on it and its very very adjustable.
Why wouldn't you just edit the appropriate tables?.
It just seems like correcting the calibration would be the simpliest way of doing that. And doing that gives you complete control of adjusting it's calibration, at every step, for the best possible resolution.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Youd probably have to do both. Adjust to get the desired output range, and then recalibrate on the ecm side.
Car: An Ol Buick
Engine: Vsick
Re: Re: Re: MAF sensor enlargment
Originally posted by Grumpy
How's development going on the original source code project?.
had to park it for a while. got a living to earn. get back to it closer to winter.
ahh the translator that i helped develop has 10 PC calibration points for its transfer funtion. so you can have a ton of low flow resolution and then ramp it up later in the flow curve to WOT fueling where the error % doesnt work against you so much.It was a feature that i made sure when the device was being developed was input into the device.
device feature i dont know why there not on the website
rs232 serial communications
flash calibrating
10 point transfer function both the FQ in and the voltage out points are adjustable.along the scale so they can be moved
Fq in V out
FQ in and FQ out
V in and FQ out
V in and V out.
and by the way the tpi computers (1k pull up instead of 10k) require alot of drive current on the MAF end just check the schematic.
Car: 87 T/A
BumpaD82
Feb 26, 2016 02:57 PM
Linson
Sep 21, 2015 01:08 PM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
