help w/ homeade aldl
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
k fellas i got a double wammy today i got my car back and got a free laptop....the laptop needs a batt. and the place where the charge plug goes in needs resoldered it works but its loose....but any way the laptop i got has a 25 (20 somethin anyway i dont have it in front of me at the time) pin serial not a 9 pin i had the link r bob gave me but cant find it i just need to know the right pins for the 25 pin serial so i can switch them out if that makes since the one i built is this one minus the bridge and resistor between a and b ports
http://winaldl.joby.se/interface2.gif
please help if u can thanks
John
John
Engine: 305 tbi l03
actually it may have been bmonte actually to link me the schematic so if either of u see this please post it or pm it to me again thanks
John
John
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
Are either of these what you're looking for......?
http://www.jspayne.com/io/schematics.html
http://www.beyondlogic.org/serial/serial.htm#2
(Have to scroll down a bit to get to the "good stuff" in the 2nd link.)
Engine: 305 tbi l03
i could only check the second one because im at work and our proxies block .coms but yeah that should work just fine as long as those are correct...thanks
