Disabling VATS in $61 code.
Old Oct 13, 2005 | 07:53 PM
justme's Avatar
I am working on a 92 TBI Camaro and can't find a ECU file for the $61 with a switch to disable the VATS. Can someone tell me which Hex location to change and what to change it to to disable VATS.
Thanks,
Old Oct 13, 2005 | 08:55 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
http://www.moates.net/fileman/index....%20Definitions
Old Oct 13, 2005 | 09:12 PM
justme's Avatar
Tried that one with Tunerpro, but I am used to playing with Tunercat and having a enable/disable checkbox. Couldn't find anything that specifically said VATS disable in that def. file.
Old Oct 13, 2005 | 09:57 PM
Dave_Jones's Avatar
OK, how about the $61 hac then?
http://www.moates.net/fileman/index....%20and%20Hacks
Code:
LD007:	FCB	$24	; option byte: 0010 0100
			; b7: 1 = Shift Light (0 = tcc)
			; b6: 1 = VATS enable
			; b5: 1 = high gear sw polarity
			; b4: 1 =
			; b3: 1 =
			; b2: 1 =
			; b1: 1 =
			; b0: 1 =
Old Oct 13, 2005 | 11:05 PM
JPrevost's Avatar
Car: 91 Red Sled
Old Oct 14, 2005 | 03:59 AM
justme's Avatar
Hey, thanks. I was trying to open it with an old verison of Tunerpro I had downloaded that wouldn't open an .xdf file. The file I had was a .ECU file that only had "Options @ ?" and "Diagnostics @ ?" in the flags section. l Opened the .xdf file in new TunerproRT I had and it works.
Old Oct 14, 2005 | 06:16 PM
JPrevost's Avatar
Car: 91 Red Sled
ALWAYS upgrade your software... hardware not usually required (like in our car's computers) but software, ALWAYS!
Old Oct 15, 2005 | 05:13 AM
DM91RS's Avatar
Car: 91 RS
Jon....... is that the utbi code you running there?
Old Oct 16, 2005 | 02:07 PM
JPrevost's Avatar
Car: 91 Red Sled
RS Reaper
Oct 17, 2018 07:52 PM
dusterbd
Sep 29, 2015 08:40 AM
AmorgetRS
Sep 28, 2015 09:33 PM
Winchester1094
Sep 15, 2015 09:48 AM
