Enough voltage?
Old Nov 9, 2005 | 11:01 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Enough voltage?
for you guys using the DTR pin on your home made cables to power them, did you have exactly 12 volts? I just checked mine w/ a volt meter and was getting ~8.73 DC volts is this enough or do I need to tap into the car's power?
Old Nov 9, 2005 | 11:20 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
That should be fine. It is usually the negative swing where the problem occurs. Is this a MAX-232 setup or a two transistor.
Don't run a two transistor on a LT1 PCM.
J
Elephantismo
Feb 13, 2019 12:51 AM
327IROC85
Sep 23, 2015 12:11 AM
eustodp
Sep 20, 2015 05:09 PM
ULTM8Z
Sep 16, 2015 09:15 AM
RyanJB
Sep 2, 2015 01:27 PM
