730 tuning problems
Old Nov 12, 2005 | 06:45 PM
anondude13's Avatar
730 tuning problems
I have a 730 in my GTA, and I've been trying to tune it since I did an injector swap. For the first 30 minutes or so of driving, the car goes into closed loop like it should, and my BLMs are normal. After a while it starts to really screw up... I start getting wicked high BLMs and the car spends most of its time in open loop, I get SES's and the car stalls if it tries to idle. I got one error code in the process of all this, code 33 or "MAP high." I want to believe it is the MAP, but the MAP seems to be behaving normally when I tune. I think there is something wrong with one of the sensors, but I'll never figure out which one it is without your help. I have a copy of my datalog where it threw the DRC attached.
Here is a copy of a datalog from when it was running ok:
http://www.people.virginia.edu/~blr6k/vefckrpub2.uni
Here is a copy of the datalog after it started screwing up this is also the one where it threw the DRC:
http://www.people.virginia.edu/~blr6k/vefckrpub4.uni
Old Nov 13, 2005 | 08:46 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
R u using an emulator of some type?
Or an Ostrich? etc?
First, put the stock equivelant chip/memcal in and see if the problem exists.
More than likley it will go away. Than try one piece at a time to see where the problem lays.
Sounds like if u might have a bad pin or connection somewhere.
Code 33 tends to be common for me when I am having connectro or zif socket issues.
later
Jeremy
Old Nov 13, 2005 | 10:59 AM
anondude13's Avatar
Indeed I am using an ostrich. I'll check out my socket connection today. I've also heard that it could be a bad ground or something. If you look at the O2 readings my O2 basically stops working for some reason. Whatever happens, updates will be posted tonight.
Old Nov 13, 2005 | 05:11 PM
anondude13's Avatar
Problem solved. The heater valve vacuum line was unplugged, which made it difficult to tune. Thanks for the input.
Azrael91966669
25
Jun 20, 2017 04:04 AM
nuggie
Aug 25, 2015 01:27 PM
soarestransam
Aug 24, 2015 08:15 AM
355tpipickup
Aug 19, 2015 10:02 PM
zeitghaist
Aug 18, 2015 07:33 AM
