starting with 730 ecm now.
Old Nov 30, 2005 | 01:50 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i usually play with my own maf chips but now my buddy wants me to help him with his speed density chip, a 730 chip. i cant seem to figure how to properly read this bins? what xdf file do i need to load (using tunerpro)
Old Dec 1, 2005 | 03:16 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Read the ALDL or the BIN?
What is "Blowed up?"
Old Dec 1, 2005 | 04:41 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Did you look on the TunerPro site?
http://tunerpro.markmansur.com/downloadBinDefs.htm
Second definition down. 1227730. ;-)
Old Dec 1, 2005 | 07:27 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Blowed up is a destroyed piston and pretzel stick rod and a locked up engine. I was curious, so I searched out his recent posts. THAT SUCKS! Sorry. But, I've read that a 383 is now in the works
$8D is 730.
Can probably use AUJP. Or read the original chip and edit it.
I used to live close to the guy he's doing it for (I'm still in Chiner), and even talked to him before. I'll try to come back to Cali for a few days in January, so if you have problems, maybe I could help (could even throw it on the dyno in SLO if he's up to it).
Old Dec 1, 2005 | 07:28 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: starting with 730 ecm now.
Depends upon which mask that '730 is running. If a Thirdgen then it will be either the $8D or the $88 mask.
RBob.
Old Dec 3, 2005 | 11:44 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
it is actually a system out of a vette. late model im sure.
i also figured 8D is the one, however its not an .xdf its a .ecu so im really not sure how to load this up properly with tuner pro. i can only go to the XDF file and select xdf.. but i cannot select the .ecu bin. theirfor i cannot properly open any 8D bins. anyone catch what im saying?
Old Dec 3, 2005 | 11:57 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
...however its not an .xdf its a .ecu so im really not sure how to load this up properly with tuner pro. i can only go to the XDF file and select xdf.. but i cannot select the .ecu bin.
In the XDF pull-down menu, there's an "Import" function, that will let you load up the .ecu file
You can then save it as an .xdf if you want.
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
in the same place where you select the XDF file, you want to "import" the ECU file instead.
**EDIT**
Dave was a little faster than me
Old Dec 4, 2005 | 12:15 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks! then i went save XDF and i named it 8D.xdf so now i can just open the xdf correct? i hope i did it right. the spark map for the 730 bin looks normal now lol. where can i find this fueling table vs rpm now? i cant seem to find it.
Old Dec 4, 2005 | 12:25 AM
Z69's Avatar
Z69
8D.xdf or Super_8dm2.ecu on moates.......
There are 4 main places to look for things.
Moates
Tunerpro
DIY-EFI
This forum
Where's the VE table
Look at every single item in TP!!!!!
Old Dec 4, 2005 | 12:27 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
TP?
Old Dec 4, 2005 | 12:38 AM
Dave_Jones's Avatar
TunerPro
Old Dec 4, 2005 | 12:43 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i thought with the 730 bins that their was an actual table that was fuel VS rpm. am i wrong?
Old Dec 4, 2005 | 12:46 AM
Dave_Jones's Avatar
Volumetric Efficiency vs. MAP vs. RPM
There are two VE tables, main and extended, based on RPM.
Old Dec 4, 2005 | 12:48 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
awesome thanks!
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Jae992
Aug 27, 2015 09:07 AM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 19, 2015 12:07 PM
