'Throttle kicker' in TBI PCMs
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
What does this do? Is it basically just using the governor actuator to open the throttle?
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
If-in your talking about like on a caddy, it pushes on the throtle linkage to open the blades to add air like an IAC.
Car: An Ol Buick
Engine: Vsick
Re: 'Throttle kicker' in TBI PCMs
As mentioned ISC, instead of IAC?.
Antisipated Radiator Fan turn-on?.
P/N gear change.
There probably are others.
Dunno guvenator actorator...
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
If you are talking about the ISC motor there is quite a lot of talk about them a few threads down in this thread: https://www.thirdgen.org/techbb2/sho...hreadid=331767
Car: 88 Camaro SC
Engine: SFI'd 350
That seems to fit the evidence at hand quite nicely. There is a bit in a CPU hardware addr. that is toggled on and off. It also adjusts the base TPS reading accordingly.
I guess the ISC mustve been an option, or a proposed option, for the throttle body trucks.
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by Fast355
The ISC is vacuum controlled on some 454 trucks. They still have the typical IAC, but they also have a vacuum control on the driverside front of the TBI.
Edit: Sorry, just re-read the quote, it is not vacuum actuated, but rather as I mentioned, an electronic solenoid.
Car: 88 Camaro SC
Engine: SFI'd 350
That appears to be what it is. It works with the IAC to control the idle. My guess is that it was included on the trucks that where likely to have engine driven accessories that placed a large load on the engine, or some other form of large external drag.
Car: 88 Camaro SC
Engine: SFI'd 350
Another neat thing I found out from this is that the TPS is scaled to further take advantage of its range. Basically that means that pretty much all the tps values in the hacs floating around are probably wrong. Oh well, its only about a thousand entries to track down and fix, but hey, no biggie.
Car: 1989 Iroc-Z
And the one on the 93-95 Northstar. Appears to be the same one just with a mounting bracket.
not at all like mine? mine is a circular diaphragm(2.5 inch?) with vac line and a throttle stop screw like devise that pushes open the throttle. vac operated. those appear as electro-mechanical.
Car: 88 Camaro SC
Engine: SFI'd 350
There appear to be two seperate outputs for the 'throttle kicker', which is a 1/0 type of deal, and I think a PWM output for the governor, which is controlled by a PID routine with the final derivative, prop. and integral terms constituting the output. Id still like to see what you have, Ronny. I suspect that may be the governor. From the code side, the governor appears to only be able to activly close the throttle. Maybe somehow the ISC and governor are all combined into one device?
Car: 88 Camaro SC
Engine: SFI'd 350
The governor has to be in there somewhere. Maybe the 'ISS' works off of vacuum? Its possible for the governor to work off of vacuum for a period of time off of the vac canister. Maybe looking at it will tell more.
EDIT: On the '94 trucks there is only the one output for the TCC on the auto trucks (E10) on the '95 trucks there are two, E10 for the TCC solenoid and E11 for the PWM TCC solenoid. E11 bieng the assosciated second PWM output.
Car: 88 Camaro SC
Engine: SFI'd 350
In the $0D, the 'governor' is tied to the shift light/non PWM TCC output (pin E10) and is a fully PWM output that is definatly a governor. Full PID engine speed control based off of TPS, MPH, engine speed, etc. with no reference to idle anywhere.
Havnt dug in yet but the 'throtte kicker' is tied to a seperate output. Its an on/off type of deal with what looks like the IAC integral terms and engine idle speed deterimining when to flip the bit. That one is also on a seperate output.
Also present is what appears to be the PWM TCC output, only used when an electronic trans is present. Again, this is also on a seperate output from either of the previous two.
All three output to seperate hardware addresses in the PCM, and presumably to different pins as different outputs.
Im not the hardware expert end of the deal here so Im sort of perplexed. From the software side, its a governor, almost no doubt, but from the schematic above, its the ISS. WTF?
Car: 88 Camaro SC
Engine: SFI'd 350
Forgot all about this. Good thing I had my moderator hat on and brought all the info in when posting in an old thread on this or it wouldve been lost forever. It was origionally a stupid ebay link.
First the pic...
First the pic...
Car: 88 Camaro SC
Engine: SFI'd 350
The governor looks like it works just like I thought it would. The throttle bracket is probably spring loaded and doesnt actually open the throttle directly. The motor probably forces the throttle closed against the spring and the rate/position is dependant on the current supplied to the motor.
Car: 88 Camaro SC
Engine: SFI'd 350
The governor is something that only came on the big cargo trucks if I recall. Might it also be safe to assume that the ISS was really only used on the vehicles with a manual trans?
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 88 Camaro SC
Engine: SFI'd 350
The stupid ebay link thing wasnt directed toward you, BTW. Those drive me crazy to no end since they die and the thread becomes meaningless.
Its neat that they have an entirly different casting just for that.
HaulnA$$,
If I remember the linear EGR on my '93 was just a spring loaded pintle with a solenoid coil(?) on the back. At WOT the weak little spring would allow it to blow open and slag from the CC in my clapped out 4.3 would blow into it and lodge it open, causing horrible idle issues. That and the string of bad, leaky CPI injectors always caused problems. Man I hated that truck...
It would be cool to get some pics of the throttle kicker.
HaulnA$$,
.....HaulnA$$,
.....HaulnA$$,
Car: 88 Camaro SC
Engine: SFI'd 350
Thanks. The throttle kicker there looks alot like the ones on the old q-jets. Is it just a coil inside that pulls the actuator out?
Car: 1983 G20 Chevy
Transmission: 4L60
There is also one controlled off of vacuum that looks similar to the Idle Load Compensator on an 80s 307 Olds carburetor. Mounts in the same fashion as the electric.
Car: 88 Camaro SC
Engine: SFI'd 350
Oops... Looks like the S/L and governor are on the same output as the 3->2 shift solenoid.
Car: 88 Camaro SC
Engine: SFI'd 350
And it looks like the TCC is on the same pin as the ISS, as an on/off output. No mystery after all.
Car: 1983 G20 Chevy
Transmission: 4L60
Guys, the trucks that would use a governor would have a Non-Computer controlled Allison 4 spd automatic behind them!!!! The 454 motorhomes do not have a governor. The governor is to keep some worker from overreving the truck or going 100 mph with a heavy load. Think of the super low gearing that most dump trucks, U-hauls, School Buses, etc have. Something in the range of 6:1 with NO OD. That makes for an engine that is turning about 3,800 @ 60. IIRC, most trucks are governed at 4,000 rpm which would give you like 63 MPH. If you tried to drive one at 70 it would push the RPMs up to lik 4,600+ and kill an engine very quickly. Any less gear and the truck would not start off up-hill when fully loaded.
Car: 88 Camaro SC
Engine: SFI'd 350
As far as all the outputs go, the previous comments give the incorrect impression as to what the outputs are really used for. Ignoring the comments and visiually tracing the code tells what outputs are actually used for what.
The following link (see bottom of post) is a pic of the part in question 'Idle speed control actuator'. The pic is from my 1994 GM P-30 chassis RV (Southwind Storm) 454 TBI w/4L80E trans.
figured I bring this to folks attention since it's often referred to incorrectly or even unknown by many. For the older TBI engines (454) there is a vacuum can attached to the throttle cable on the drivers side of the TBI.
This vacuum can is the 'Idle speed control actuator' aka as 'Throttle kicker'.
It serves a few purposes...
As for the 'Idle speed control actuator' it was not installed in all models of GM. I believe only in the truck models such as the P-30 chassis. It is the vacuum can on drivers side of TBI attached to throttle cable. It has a vacuum line running to the 'EGR valve control solenoid' which is on the passenger side of the TBI just forward of it attached to a bracket.
See pic of mine for aforementioned items: https://www.dropbox.com/s/ow3nt7k4hf...B1%5D.jpg?dl=0
Idle Speed/Throttle Actuator - Mechanical: Description and Operation
Purpose: The idle speed control actuator system assists the idle air control system in controlling the idle speed, primarily at cold temperatures.
Operation: The idle speed control actuator is a vacuum operated device which opens the throttle slightly (2 to 3 degrees of angle) to increase the cold engine idle speed, to improve the mixing of the air and fuel, and to allow lower warmed up engine idle speeds. The idle speed control actuator is controlled by the EGR valve control solenoid, which is controlled by the power control module. To increase the idle speed, the EGR valve solenoid is turned "OFF," and no vacuum is routed to the idle speed control actuator, allowing it to open the throttle slightly. To decrease the idle speed, the solenoid is turned "ON" and vacuum is routed through the solenoid to the idle speed control actuator, allowing the throttle to fully close.
In conjunction with the idle speed control actuator system, the idle air control continuously monitors and controls the engine idle speed to the desired idle speed. A Tech 1 scan tool will read the control module commands to the idle speed control actuator system.
The throttle actuator provides another function. The larger the TB, the more the bores expand as the engine gets hot. The 92+ 454 equipped truck ran much hotter than the older square body version. And GM had switched to a heated intake instead of the small heater plate, which was much more effective at heating the TB and keeping it warm after the engine was shut off. Well, a larger bore means the throttle plate must be closed more to keep idle speed low. No problem, right? Just reduce minimum air by turning the throttle stop and you're done. But if you do that when the engine's hot, the next day when you go to press on the accelerator while the engine's cold, the throttle plate is stuck. Not so good. The throttle actuator allowed a way to reduce idle speed when hot yet keep the throttle far enough open when the engine was off so a cooling TB wouldn't seize the plate.
The following is the correct OBD-1 code chart for the early 90-95 years: https://www.troublecodes.net/gm/#codesobd1
As for the adjustment of the 'Idle speed control actuator' (Vacuum can) aka throttle kicker...
Idle Speed Control Actuator Adjustment
Procedure: (from manual)
Before adjusting ISC actuator you must first check the minimum idle speed to be within specifications. Refer to SPECIFICATIONS/IDLE SPEED. (ISC actuator must have vacuum applied so that it is not contacting the throttle lever.) See image VIEW A.
Remove vacuum hose on ISC actuator on warm engine.
Adjust ISC actuated idle speed to 1300 +/- 50 rpm. See image VIEW B.
Install vacuum hose.
In the event the vacuum can is leaking and not holding vacuum and you're unable to source another. You'll need to get at the 'Idle adjustment screw' that is covered by GM on the front side of the TBI. Turn it open roughly 1 turn. This will open the throttle blade slightly. The IAC will/should make up the difference.
Prior to doing this you must make certain that the min idle speed is set first
https://www.dropbox.com/s/ow3nt7k4hf4gimd/20180512_232309%5B1%5D.jpg?dl=0
Just in case my above Drobbox link does not work it (ISC) is also pictured here: (item #16) https://lt-truck-gmc.7zap.com/en/g15...623891437-0-0/
Part number:
Part number:
GM 17084953
I am so glad I found this post! DOnt suppose you have the images from the manual so I can carry out this procedure? I have a problem with engine stalling after revving on my RV I have checked and changed everything else, but didn't know the procedure for setup. I wasn't even aware of the idle adjustment screw .
TheTraut88
Sep 7, 2015 05:22 PM
92camaroJoe
Aug 13, 2015 06:07 AM
