tuning boost with $58
Old Jan 17, 2006 | 04:58 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I was using the $58 .xdf in tunerpro and looking at some stock bins. The VE table only goes to 100kPa. the spark table goes to 200kPa.
The question is... how do you adjust fuel when in boost?
Old Jan 17, 2006 | 05:12 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: tuning boost with $58
There should be another table.
Boost multiplier or some such thing.
It mutiplies the 100 K/Pa levels above 100 K/Pa.
Old Jan 17, 2006 | 05:53 PM
I figured it was something like that, but I can't figure out which table does that.
Old Jan 17, 2006 | 07:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I'm thinking this may be the table you are looking for:
Code:
/* Item 1: Base Boost Term */
/*startAddr                 =60D,
/*columns                   =1,
/*rows                      =11,
/*elementSize               =1,
/*bitMask                   =0,
/*offset                    =0,
/*mulOrDivOrBit             =0,
/*factor                    =0.0078125,
/*map_name                  =BOOST - Base Boost vs MAP,
/*ylabel                    =MAP,
/*yaxis                     =   90  100  110  120  130  140  150  160  170  180  190,
/*xlabel                    =Factr,
/*xaxis                     =,,
Multiplies the current PW by the table value based on boost level.
RBob.
Old Jan 17, 2006 | 08:16 PM
In the $58.bin file I am looking at, the values in the chart are mostly 1 with a few 1.7's at high MAP. Which pulsewidth is the current one? the one from the 100kPa column at current rpm after all multipliers? this seems like it would be running lean untill high boost (with 1.7 multiplier).
I hope this doesn't make me look like I don't know what I'm talking about, and I don't.
Old Jan 17, 2006 | 08:36 PM
I opened a different .bin file and opened the 'BOOST - base boost vs rpm' table. It looked different this time. It was a VE table with MAP across one axisfrom 38kPa to 100kPa. I want to assume that these are gauge pressures instead of absolute pressures. the VE's increase from 44 to 95 with MAP. There is also a 'VE adder' table with values around 30. so does this mean the VE of the stock sy/ty motor was about 125% at 14.7 psi? I guess that sounds reasonable.
I converted the PW's of my commander 950 program to approx. VE's for my motor using the injector flow rate and AFR. I got like 159% at 149kPa. that seems impossible, I guess the injectors are smaller than I think. Stock LT1's are 24 lb/hr, right? Or I used the wrong density of air and gasoline.
Old Jan 17, 2006 | 09:14 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Do you have the address for that table? And, what ECU/TDF file are you using?
RBob.
Old Jan 17, 2006 | 09:22 PM
its a bbzb58.bin from moates.net and the 58RR_v14.xdf for tunerproRT v4.13
address: 03C2
6 rows
6 columns
Old Jan 18, 2006 | 07:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
address: 03C2
6 rows
6 columns
OK, that table is the desired boost for wastegate control. The table should be by TPS% and RPM.
RBob.
Old Jan 18, 2006 | 10:57 PM
Originally posted by RBob
Code:
/*startAddr                 =60D,
/*columns                   =1,
/*rows                      =11,
/*elementSize               =1,
/*bitMask                   =0,
/*offset                    =0,
/*mulOrDivOrBit             =0,
/*ylabel                    =MAP,
/*xlabel                    =Factr,
/*xaxis                     =,,
RBob. [/B]
I can see how this can help tune fuel in boost, but is there a table that depends on rpm also? or does it use the VE table and multply the VE by the boost pressure.
example of what I'm saying:
given:
355cid
4000rpm
MAP=150kPa
From VE% table:
VE[4000rpm,100kPa] = 54% (+30% adder)
so does it calculate:
'current VE' = 150kPa/100kPa(54%+30%) = 126%?
then calculate a 'current PW' for those current conditions according to injector flow rate... then multiply by the number in the table at 150kPa:
for example 1.07
to get: actual injector PW=1.07(current PW)
not counting other adders
It frustrates me when I don't know what the ecu is doing with the values in the tables.
$750 L98
Feb 1, 2025 02:25 PM
