AE and PE Zeroed Out
Old Jan 17, 2006 | 05:39 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Im playing around with a "new" but stock bin AXXB and all the Enrich Power and Enrich Accel tables are zeroed out. In general is that basically saying "im not getting and AE and PE mode"? I like the tune as a starting point and im willing to try and learn each table alittle better. Just wondering if i need to start working on these tables or leave them be for now.
Old Jan 17, 2006 | 06:10 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I'm thinking "your new but stock bin" isnt a virgin.
I've never seen a SD 90-92 bin with any PE or AE tables zeroed out.
Might want to tread real carefully here or see if u can try mathcing it against another one you can find or if someone can send u one.
later
Jeremy
Old Jan 17, 2006 | 07:43 PM
JPrevost's Avatar
Car: 91 Red Sled
later
Jeremy
Old Jan 17, 2006 | 08:16 PM
87_TA's Avatar
Make sure you are using the right def code $8d, or what said above..
I have done that before, some tables show up with value's and some do not.
Old Jan 17, 2006 | 08:35 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I did Tunerpro .bin compare to the S_AUJP_V.3 so i could copy the CCE setting to delete them in my "*****" chip I didnt see alot of difference other than "Item Not Defined" differences.
I got the bin from 87TPI7749. Its the closest thing i could find to the AWFY, which is in my memcal right now. I cant find anything else. Looking for AWFY Thread Ive went over it pretty throughly and it seems good but i didnt use a fine tooth comb.
I guess i better check it out some more. I have driven on this .bin and scored a nice looking datalogg. For what it counts.
Old Jan 24, 2006 | 03:25 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
AWFY - isn't the the 305 TPI dual cat manual tranny BIN? If so, it was superceded by GM with AXYC for the '91 cars. And I can give you a new copy of that one. I did the same hunt a couple of years ago, and that's what I found out, hence my using AXYC as the base for my 383 manual BIN..... (but I'm helping field test the AUJP_MT version 4 right now.....)
Old Jan 24, 2006 | 05:17 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Im hoping it isnt since im running a 700R. Its what i read straight out of my memcal. Whos to say it originally came with the car though.
Thanks anyways man.
Old Jan 24, 2006 | 05:40 PM
vernw's Avatar
Sorry, I was "thinking" wrong.
AWFZ was the 91 305TPI dual cat manual tranny bin file.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Elephantismo
Feb 13, 2019 12:51 AM
blackz281le
Jan 11, 2016 07:51 AM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
