Has anyone blown up there engines from a bad tune?
Car: 1994 Trans Am
Has anyone done that before, like when they first started prom burning? Because with my luck, the first chip I burn will do that.
I just got a PC computer, and my car blew the engine, but I will get some new heads, cam, cheapie headers, AFPR, 22lb injectors and rebuild this franken-motor to something much more powerful. But I have the stock 5.0 SD prom. The block was replaced with a 350 block (638 stamp underneath) by the previous owner.
So when I get the software and everything else, what are the values that I should change to and from that will help me out most? I understand that some dyno runs in between will help further, but for starters where should I look?
Thanks!!
-Kevin
Thanks!!
-Kevin
Car: An Ol Buick
Engine: Vsick
Re: Has anyone blown up there engines from a bad tune?
