16 ppr hall effect sensor
Old Mar 20, 2006 | 02:17 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i have an autometer hall effect sensor that puts out 16 pulse per rev. currently i am not running a VSS on my car since i switch to autometer gauges. If i remember the stock cluster puts out 4k PPR or something like that. is there anyway that i can make the hall effect sensor to put out the correct ppr like changing the speedo gear or do i need to go with a digital dakota box. i also am running a t56 if that makes any difference. thanks
Old Mar 20, 2006 | 03:16 PM
91L98Z28's Avatar
Car: Z28
if i remember correctly, stock is 4000 pulses per _mile_.
if your setup is giving you 16 pulses per DS rev, you need to figure out how many pulses per mile it's giving you to figure out what you need to do.
sometimes GM used a "DRAC" which could convert pulses as well, and they can be found in the salvage yard. unfortunately i don't seem to have any of these threads about the DRAC in my subscribed threads, and with search currently down I can't locate any for you.
Old Mar 20, 2006 | 05:24 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Here is the link to the DRAC modification thread.
https://www.thirdgen.org/techbb2/sho...hreadid=346332
Might do the job.
4 PPR comes out to the 4000 per mile IIRC.
Sounds like there should be a way to use it.
The "Optical" VSS input uses pin "C6" on the 730 and wants a 5 VDC square wave input. The pulse count "appears" to be much higher than the mag sensor but I don't exactly know what it is.
The $8D code uses a multiple of 461 divisor (461, 922, & 1382) on it to come up with "Road Speed Pulse" multiplier value. Don't know all the details how its working. There was a thread discusing it previously but I don't have it bookmarked.
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
billybob6110
Sep 23, 2015 01:30 PM
ASE doc
Sep 22, 2015 03:13 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
