**6E XDF file with SES Code "switches"**
Old Apr 12, 2006 | 08:02 PM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 4:11 posi
I have an XDF file with all the SES codes in the Flags/Switches portion of TunerPro RT, I just need a place to upload the file so those of you who want it can gain access. I can't upload it to Craig Moates FTP site so I wandering if there is another place? Also this XDF file has the O2 upper and lower zero reference voltage. Thanks for the help.
Old Apr 18, 2006 | 06:11 PM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
**6E_O2_SES file upload**
Okay here it is hopefully you will be able to upload this .txt file and save it as an .xdf file to use if you need the "SES" switches in TunerPro RT.
File Type: txt
Old Apr 25, 2006 | 10:58 PM
88 IROC CONVERT's Avatar
Car: 2002 zr2 Blazer 88 Iroc convertable
Engine: 305 T.P.I.
How do you get it to show that in tuner pro?
Old Apr 26, 2006 | 02:09 AM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
$6E
Open the TXT file should look like this:
XDF
1.110000
DO NOT HAND EDIT!!!! (Trust me)
%%HEADER%%
001000 FileVers ="0.9"
001005 DefTitle ="89 165 ECM 6E And Stuff"
001007 DescSize =0x29
001006 Desc ="This is for 1227165 $6E (1989 F-Body and "
001010 Author ="Mark Mansur"
001030 BinSize =0x4000
001035 BaseOffset =0
001200 ADSAssoc =".\\6E.ads"
001225 ADSCheck =0x23AB0
001300 GenFlags =0x0
001325 ModeFlags =0x0
002000 Category0 ="Fuel"
002001 Category1 ="Spark"
002002 Category2 ="IAC"
002003 Category3 ="Fan"
002004 Category4 ="Idle"
002005 Category5 ="BLM"
002006 Category6 ="INT"
Click on file then save as and where it says 6E_O2_SES.TXT replace the .TXT with .XDF and save to your desktop or the bin definition section in TunerPro RT.
Old Apr 26, 2006 | 02:24 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
what does this do for us?
Old Apr 26, 2006 | 03:14 AM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Someone may have already done this, but you can turn on or off all of the SES codes individually. I was getting a Code 54, but since I do not have the in-tank unit this was a code that did not apply to me. Just thought it might help someone get rid of their SES light.
Old Apr 26, 2006 | 08:00 AM
Engine: 305 T.P.I.
When I use the file above with tuner pro it shows all the switches instead of bit 7 bit 5 etc it says what they are. I am new at this and can not see how to do that with others files. I was looking at different ecu and bins trying to get a handle on wtf is going on. This is the first time I saw any "REAL" info in english
Old Apr 26, 2006 | 12:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
sweet thanks!
Old Apr 27, 2006 | 03:27 PM
clippjr8's Avatar
Nice job on the XDF file. It looks to be very correct.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Luigytico09
Oct 1, 2015 08:46 AM
