high idle in park low idle in drive. cant find a happy medium :(
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
in park or neutral it runs idle at aroun 1700 and in gear it barely runs at around 500rpm. what the heck do i mess with to get it to idle correctly? i would like it around 800-900
Car: '02 Z06
Engine: L33 5.7
ill let u know tomorrow when i return from work and datalog it. maybe having some hard numbers will help? that would make sense having a bad iac.
u want whats called "IAC motor position" ? thats the only thing i see besides desired idle rpm in tuner pro RT
Car: check
Engine: check
Transmission: check
What to look for is if the IAC is being closed while the idle is at 1700 RPM. Then is it being opened while the idle is low at 500 RPM.
RBob.
Car: '02 Z06
Engine: L33 5.7
0 steps i closed i assume? cuz if so, then it looks like the ecm is functioning the iac normal. at idle when it fires up its zero. and when i tap the gas however i see the counts jump up then back down to 0 quickly. when idling normal and then once it acts up ( a few minutes after driving) it still reads 0 steps when the idle is 2200rpm!
Car: check
Engine: check
Transmission: check
There is either a vacuum leak, the throttle blades are open too far, or the IAC is bad.
I'd try to figure out if the IAC is closing. Maybe short A & B on the ALDL and key-on, engine off. Is the IAC clicking?
RBob.
RBob.
Car: '02 Z06
Engine: L33 5.7
yea i can feel the iac valve buzzing when i go to unplug it to adjust idle. i do need to note that when its a fresh start it runs fine even letting it idle it will creep up very slowly, or i drive it 3 minutes and its up there. when i set my idle, i had to bring the throttle blade pretty open to keep the engine running, it said to set it at 450rpm but my engine wouldnt even run until it was up to around 600rpm. so thats where i left it. i think i need to reseal my intake i have an oil puddle very slightly near a bolt. maybe that and then a readjustment of idle and i can check up on it again? any other input for me? does the iac sound good?
also my timing with esc disconnect i have it up to around 18degrees to get it to run smooth. does this indicate anything? i changed the base rpm in the prom to make it match however.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Originally Posted by RBob
Yes, I worded it the way I did as the ECM has no idea where the IAC really is. It just pulses it, and if it doesn't move the ECM doesn't know that.
RBob.
RBob.
92camaroJoe
Aug 13, 2015 06:07 AM
