NE1 run 60lb hi-z injectors and $58 code?
Car: Used to drive a camaro
So my car is finally put back together and I've been able to turn the engine over, it rumbles, farts, pisses, then stalls. I'm attempting to adjust for the 60lb injectors but wanted to ask if anyone had pointers before I go into it. I've done some searching but haven't turned anything up that really helps.
Car: An Ol Buick
Engine: Vsick
YMMV
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
With the Ford 42#/hr saturated and Siemens 55#/hr P&H I had to play around with them on the bench to see how they flowed.
Originally Posted by Grumpy
If your talking about the pencil type 60s, they use a fairly long PW at low RPM. as in they weren't too much different the with my 40s. But, as the times get of over 3msec they start moving alot of fuel.
YMMV
YMMV
I am curious on the brand and part number because I would like to stay away from injectors like that if they are very non-linear in certain regions that can't reliably be corrected for. Did you fix up the problem with the VE table or another "non-linear BPW correction" table?
Grumpy, thanks for the info.
Junk, I bought them from Lingenfelter: "Siemens 60 lb fuel injector" Flow: 6.9-10.7 g/s @ 250-600 kPa
Impedance:12.5 Ohm
I haven't been able to get it to even idle yet (only have worked on it for about 3 hours.)
Impedance:12.5 Ohm
Car: An Ol Buick
Engine: Vsick
3 hours... sounds like it's fighting you, the changes you're making aren't big enough, or you technic needs improving. I say this as inspiration, not knocking you.
Engine: 3xx ci tubo
I tend to hone in the BPW using a different approach. This may or may not work for you.
1) calculate the proper BPC for your engine and injectors
2) reduce the 1200 RPM and lower VE values by 30% for the %58 code
3) reduce the crank BPW (AFR) by 10% for the %58 code
4) connect up the ALDL link
5) hit the record to file
6) look at the recorded BPWs (and WBO2 AFR if available)
Using that method it took about 5 minutes to get my second $58 install running on a new engine, new injectors.
If what Grumpy says about the 60#/hr having large BPWs at idle and cruise is true then you should by fine. If it is BS, then you will have sub-millisecond BPWs and the stock qausi-fueling is going to give you a challenge and the 60#/hr most likely will not work. I hope what he said is true, but "fairly long" can mean many things depending on the cam, EFI system, etc.
Car: An Ol Buick
Engine: Vsick
It's laughable just how much opinion someone can spew in one reply, but thanks for the laughs.
Engine: 3xx ci tubo
And how much time do you have with 60's?.
Is that 3ms including opening and closing time? What you wrote was very unclear.
Car: An Ol Buick
Engine: Vsick
None.
Where was the opinion?
You can find your own parts numbers, I'm not going to waste my time, for your curiosities.
Again, thanks for the laughs.
