$8F on 730 for boost?
Old Jun 17, 2006 | 12:52 AM
busta9876's Avatar
Car: 1967 C10 Pickup
Engine: LMM Duramax
Transmission: 4L80E
Okay, the 1227730 is same as a 1227727 except 727 is for underhood mount.
$8F was the 3.1 Turbo 89-90 Grand Prix using the 730 ECM.
with a repin would this be an option for boost on a 90-92 TPI car? anyone ever gone this route?
1227730/1227749 Wiring Harness Pinout
yes the 3.1 was DIS ignition, but ECM still used the same TACH input and same EST output for timing control, should work.
Old Jun 17, 2006 | 08:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is a viable option. There is a hac of it around that has semi-commented code along with all of the calibration parameters. The important I/O will all match up (O2, EST, MAP, CTS/IAT) as they are hardware dependent. For the DIS to distributor only need to change the initial timing and the min/max timing parameters.
RBob.
Old Jun 17, 2006 | 12:59 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Be sure to flip the max retard, max advance, and reference angles around to what ever the values were in the .bin that was used in the 730 memcal. Yes, the signals are all the same, but the code runs differently between DIS, and Distributors.
Old Jun 19, 2006 | 08:27 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Why not use $58 code?
/N.
Old Jun 19, 2006 | 06:22 PM
busta9876's Avatar
Engine: LMM Duramax
Transmission: 4L80E
/N.
I was just looking at alternatives to using the 1227749 pcm for $58.
Turbo Grand Prix's used 1227727, same thing as 730 except underhood usage.
Old Jun 19, 2006 | 10:34 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Some guys are running $58 on the 730.
From the "tuning Guide"
https://www.thirdgen.org/forums/diy-...questions.html
Old Jun 20, 2006 | 12:13 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I like the 730 ECM better for high-z applications. It is usually cheaper and easier to find. The $58 code is just about a drop in replacement for the $8D code.
$750 L98
Feb 1, 2025 02:25 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
