torque converter lock up
Old Dec 5, 2000 | 08:03 PM
87Z-ya's Avatar
Already posted on the electronics board, no responses. Anyone have a schematic showing how the four wires going in to the trans for the tcc
are used? I have one in a carb v8 s10 and would like to wire it up with a button for
temporary use without removing the pan.
Old Dec 5, 2000 | 10:00 PM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
Not sure of the schematic, But yiou could check your third-gen and find out which 2 wires they are. ALl you need to do is cfind continuity fomr the A and H positions of your ALDL and the harness on the trans. They didn't change the wiring in the trans at all. just a few of the interanls.
Then just put a switch in line and you are set. Hope this helps.
Later,
lars
Old Dec 5, 2000 | 11:15 PM
87Z-ya's Avatar
THANKS lars I thought that if you jumped a and h it would activate the converter, am I right? I was trying to figure out which was power and which was ground, but your right I can figure it out on my camaro.
Old Dec 6, 2000 | 02:55 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
grounding the TCC terminal at the ALDL should do it
Old Dec 6, 2000 | 03:05 PM
Blade's Avatar
Here's a schematic showing where everything goes.
Well it looks like you would have to bring 12V to terminal A and you'll lock up the TCC. Or if your harness is instact do like mister Grumpy sugggested by shorting pins A and F on the your ALDL connector.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.org/Members/Chev...dmondIndre.htm
Old Dec 6, 2000 | 05:10 PM
87Z-ya's Avatar
My heros,,,I knew someone would come through... This one has no original wiring. Im going to try bringing 12 volts to a on the trans and see what happens. I dont believe the converter can lock up in 1st so I should be alright. I just have to figure out a way to use a brakepedal switch in line. I wonder what the other three wires going in are for? 1 would have to be a ground i would think.
[This message has been edited by 87Z-ya (edited December 06, 2000).]
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
angel2794
Sep 8, 2015 06:22 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
