will this work
Old Jan 14, 2001 | 11:43 PM
ScreaminDeamin85Z's Avatar
will this work
ok i received my "free" chps(MAX232ACPE) from Maxim the other day, i was looking at a diagram for the cable to connect to the ALDL/parallel port, and it listed the chip that i would need as the MAX232 not the MAX232ACPE, but will the 232acpe work? the cable is going to be for an 89 MAF tpi. also anyone have any links to some diagrams to make my own cable, the ones i have now aren't so hot. thanks!
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 19 lb SVO injectors, crane AFPR
(dont worry i am switching to the 89 ECM)
Old Jan 15, 2001 | 08:53 AM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
Yes the MAX232A wil work. I beleive that the Pinouts are different. And you have to change one or two of the caps. but they work the same. Just make sure the the pins reference to each otherand that the caps. are the right ones and you shouldn't have a problem at all. Do a search for the ALDL cables again one of the pages deals with this very same issue.
Later,
Lars
Read this page. It deals with the MAX232A http://www.techedge.com.au/vehicle/aldl/8192/8192hw.htm
HEY!!! Where did you get your samples from??? Fill me in man, I could use one (or two)
[This message has been edited by lars92RS (edited January 15, 2001).]
Old Jan 15, 2001 | 12:17 PM
there was apost about 4 or 5 weeks ago that siad where to go. i think the site was Maxim's homepage though.
Brandon
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
