anyone try a 6E instead of a 32B for an '88?
Old Jun 30, 2006 | 09:52 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
just wondering if this would be the better route to try.. seems the 6E is much more popular and perhaps easier to use/tune. I can't see a reason why it couldn't be used, just turn off the cold start.
anyone try this or have any reasons why/why not?
Old Jun 30, 2006 | 10:01 PM
89Vert's Avatar
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
I've done it for guys that put HSR on, cause you have to,
I prefer to use 6E for MAF cause that what my car is and that what I learned on
Old Jul 3, 2006 | 11:44 AM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
I did it,
Just disable the 9th. install a 6e and you might need to change your crank fuel muilpers table a little.. thats about it. it's a great chip, timing tables are better too, you'll see a good power gain switching up from a 32b to a 6e.
just unplug the 9th and burn a 6e to your prom and thats it. plus fuel adj are easy
Old Jul 3, 2006 | 04:20 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The later the code you use, the better.
Even at GM code goes through developement, so newer really is better.
Old Jul 4, 2006 | 02:04 AM
11sORbust's Avatar
I totally agree! 6E even runs alpha-n much smoother.
Old Jul 6, 2006 | 11:50 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Originally Posted by 8UpAFord
I did it,
Why will there be a power gain? I have both 32b and 6e and as far as I can tell their very similar. The 6e has a few more items that can be adjusted but I cannot see where any additional power will be gained?
tmellott89
Oct 14, 2015 02:06 PM
tmellott89
Aug 16, 2015 02:58 PM
MikeT 88IROC350
Jun 23, 2003 08:39 PM
doc
Dec 17, 2002 01:31 PM
TRAXION
Nov 6, 2000 05:17 PM
