1227730 ECM's applications
Old Jan 22, 2001 | 08:44 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I'm going salvage shopping and know that the SD ECM is in the following cars. Can someone help identify the make/models please? Here's the list.
Application: 1227730 ECM's
1987 2.0 L4 TBI “1” LL8
1988 2.0 L4 TBI “1” LL8 (early)
1987-89 2.8 V6 PFI “W” LB6 (exc. “W” body)
1988-94 3.1 V6 PFI “T” LH0 (exc. “W” body)
1990-92 5.0 V8 TPI “F” LB9
1990-92 5.7 V8 TPI “8” L98 (“F” body
P.S. Will I find "passkey"(VATS) in all of these cars?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Jan 22, 2001 | 09:26 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Look for a late 80s to early 90s Lumina/Corsica or Berretta...they are a dime a dozen. Also Pontiac Tempests and virtually all FWD V6 MPFI car from the late 80s to the early 90s. Just avoid "W"s.
I know that the Lumina does not have a VATS module as standard equipment. They probably have the "VATS" disabled in the V6 eprom.
To get VATS, you need the the VATS module, the ignition and the key. You'll only find that in a Corvette or an F-body of that era.
Lastly, the 4th digit of the VIN is the car model (avoid "W"s) and the 8th digit is the engine code.
Old Jan 23, 2001 | 05:26 AM
Engine: 4.0L
So the Lumina/Corsica or Berretta's did not have VATS, only F and Y bodies?
Thanks for the great infomation. I'm going shopping, you made my choices much better.
86 Camaro Sport
My Camaro Project
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
