What .bin do I use for '89 L98?
I have the arap.bin but am not sure if there are any others that the computer uses. I would appreciate it if someone would let me look at some of the things they have done to the .bin for the $6E.tdf. What does the DFCO Threshold, and injector flow rate double mean?
1989 Iroc-Z L98 Original engine-58K miles!!
SLP 1 3/4 SS headers, Hooker Areochamber catback, no cat, BBK AFPR, 3.8L Turbo V6 200* fan switch, MSD GM coil, ported and gasket matched plenum, TB coolant bypass, relocated MAT sensor, screenless MAF sensor, K&N filters, Accel cap and rotor, Taylor SpiroPro 8mm wires, Bosch Platinum plugs, Mobil 1 oil, and more to come...
Best ET not corrected- 14.24@96.76MPH / 2.17 60ft on street tires with the crappy B/W 2.77 gears.
Homepage currently under construction: http://www.iit.edu/~wicktho/len
1 Post
Car: An Ol Buick
Engine: Vsick
DFCO Deccleration Fuel Cut Off.
