CHIPS
Old Feb 2, 2001 | 07:25 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
CHIPS
I belive I have a bad chip so I wan't to go to the junk yard tomarrow and find some that will work. I am looking for 32b or 6e type of chips can any one tell me what cars these would be in.
Old Feb 3, 2001 | 12:46 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Hi 88, besides the 86-89 5.0 & 5.7 TPI "F" & "8" Vin codes, here are some alternatives:
86 2.0 L4 TBI "P" LQ5 w/MT
87-91 truck 2.5 L4 TBI "E" LN8
91 truck 2.5 L4 TBI "A" L38.
I am not certain, but the 6E only came out in the 89 TPI vehicles to the best of my knowledge. Hopefully, someone may know of another vehicle with the 6E.
Also, whether the above vehicles used 32 or 32B I cannot say. The eprom is easily re-programable and I believe there are BINs available for the 6E and 32B. The difficulty with the memcal from other engines is the ESC filter possibly.
I asked the question if a Corsica/Berretta/Lumina SD memcal could be reprogrammed to work on my car, and I was informed that no one has actually tried it, but the ESC filter may cause problems and was advised not to try it unless the memcal was a "freebie" and it was strictly to "experiment". I am still debating about doing that as I would like to pick up a spare ecm and this would cost me nothing. If there was a problem, I would expect to trigger a code 42/43/52 or see massive knock retard occur.
Old Feb 3, 2001 | 02:04 PM
Engine: ls1, LB9
I bought one from a 89 s10 mt and was able to use an 89 ecm bin(thermomaster with 24.9#inj. no vats) on it and it work ok no codes but, it just did not run as well as my stock 88 chip why do you suppose that happened it did not wan't stay running at idle after I warmed it up. my second question is how many times do you normally get to reprogram your eproms. and when they get programed and erased too many times how do you know this. do they just stop erasing? wel after 3 times that is what this one just did.
Old Feb 3, 2001 | 02:13 PM
Engine: ls1, LB9
I also wanted to note that I use the data erase II so it does shut off at the end of the erase time (2) how ever I tried erasing 3 times and all of these last three times it does not erase.
Old Feb 4, 2001 | 09:59 PM
InTech's Avatar
The datarase does not always erase quick enough.....especially when the eprom is further away from the uv light than normal....sometimes it takes longer with the memcal because it is further away from the uv light... clean the window and retry............sometimes it takes a few minutes.
-Carl
Get rid of the timer.
[This message has been edited by InTech (edited February 04, 2001).]
Old Feb 4, 2001 | 10:26 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
It takes my Datarase 15minutes to erase my MemCals ... sometimes 20.
BTW - using an S10 memcal in place of the F-Body MemCal isn't the best idea. If your car goes into limp-home mode due to a problem with your PROM then you will be screwed. The ESC filter won't be optimal for your setup either.
Tim
  • Program your own PROMs!. Read my article to get started!
  • Research and Experiment before asking questions.
  • This is not a chip store. Go to the classifieds if you want someone to sell you a chip or give you a BIN.
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
