GM Part# for Mem-Cal?
Old Feb 25, 2001 | 07:40 AM
BV's Avatar
BV
Anybody have the part # for the whole mem-cal (L98 auto) for 1227730 ecm. Local GM dealer was having a hard time figuring out what i needed. Want to start prom burning with an extra mem-cal because i will probably goof something up.
Thanxs
Old Feb 25, 2001 | 08:01 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Copied from Traxion's Prom Burning Tech Article.
"Also, for your information, the current GM (AC Delco) part number for a new MemCal unit for all 1990-1992 350 F-Bodies is 16151348"
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Feb 25, 2001 | 08:15 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The broadcast code for the replacement eprom is AUJP1615. With that number, they can get the correct part number too. The stock broadcast code is AUJP1350, but you can't buy that one anymore. The only difference between the two is the date and sequence numbers, which have no effect on the eprom's operation.
Old Mar 7, 2002 | 10:50 PM
RosiRonja's Avatar
Hi Glenn91L98GTA
I´m looking for a memcal ECM 1227730 and the 305 engine, TH700, A/C don´t know what infos still needed.
I have the possibility to programm a Prom, can I use a other one and reprogramm it?
I bought a ECM for the swap 1226870 to 1227730 but it comes w/o memcal.
Is there a source to get it online?
We don´t have things like that at the scrapyard here in Germany.
Any help would be really appriciate.
Have a really nice day in that wonderful America
Rosi / Germany
Old Mar 8, 2002 | 11:19 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
try www.gmpartsdirect.com.
Old Mar 9, 2002 | 06:30 AM
BV1's Avatar
BV1
Where did this post come from
I posted this quite a while ago.
BTW, Craigs adapter works great.
Old Mar 9, 2002 | 08:44 AM
RosiRonja's Avatar
where to get?
Old Mar 11, 2002 | 10:34 PM
gonzo350's Avatar
will the above mentioned memcal part # work with a 90 305 tpi? I assuming that it will.
Old Mar 19, 2002 | 11:03 PM
86 IROCZ28's Avatar
1990 305 TPI Memcal
They are different Memcals for the 305 and 350.
1990-1992 305 TPI memcal # 16163075
BumpaD82
Feb 26, 2016 02:57 PM
jtwoods4
Sep 3, 2015 10:19 AM
92GTA
Feb 1, 2002 11:27 AM
eddie89TA
Apr 28, 2001 01:28 AM
