ecm tuning, 1227165 ecm upgrade $32 to $6E???
Old Jul 17, 2006 | 10:40 PM
busta9876's Avatar
Car: 1967 C10 Pickup
Engine: LMM Duramax
Transmission: 4L80E
i have a buddy wants me to tune his Tune Port he swapped into a mid 80s pickup. The doner was a 1986 TPI 305 car, wich was the 1227165 ecm and the $32 byte ID. I already have a tunercat definition for the $6E for a 89 TPI.
Anyone see any reasons I can't just load the $6E code onto his memcal and run with it? Freescan will support the $6E which solves another problem with using the $32.
thanks
Brendan.
Old Jul 17, 2006 | 11:39 PM
Z69's Avatar
Z69
Just disconnect the 9th injector relay at a minimum.
Sometimes you have to tweak the crank fuel tables.
The 6E appears at first glance to be leaner than the 32. Do a compare on the relavent tables and you'll see what I mean. But plenty of people have just swapped the bin only....
TunerPro is frequently tested on 6E also....
Got any info/links on the LQ4 timing signals. Crank and Cam?
Old Jul 18, 2006 | 06:02 PM
busta9876's Avatar
Engine: LMM Duramax
Transmission: 4L80E
No not at the moment, since I sold the 6.0L I have not been up to date on the latest developement of spark control on these engines, I am however aquiring a 5.3L in the next few weeks that I plan to swap into a Mustang with a turbo, so I may investigate it some more.
I heard that Parish over on ls1tech is running the stock coils with megasquirt now, but I have not seen any info on what he did exactly.
thanks for the help.
Brendan.
Old Jul 24, 2006 | 01:49 AM
BirdsOnly's Avatar
Car: Motorcycle
I was wondering what the differences are between the $32b and $6e? I know that the 89 had the 9th injector removed? Is there any other advantage to using the 1989 $6e from a tuning stand point?
Old Jul 24, 2006 | 01:14 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
The most notable difference is:
8192 ALDL comms (10 hz) vs. $32's 160 baud ALDL comms (0.66 hz)
Also note that you'll need to disable VATS in the $6E bin in order to start the truck.
Old Jul 24, 2006 | 02:30 PM
BirdsOnly's Avatar
Car: Motorcycle
Let me see if I get this right the $6e has a sample rate of 10 hz and the $32 has a sample rate of 0.66 hz? Wouldnt that be a big advantage to stay with the $32?
Old Jul 24, 2006 | 03:00 PM
Mangus's Avatar
Transmission: T5WC
10 hz = a sample is spit out once every 100ms (10 samples per second)
0.66 hz = a sample is spit out every 1500ms (one sample every 1.5 seconds)
If you prefer exteremely slow ALDL data rates, then staying with $32 might be better for you. I have no idea why someone would prefer the incredibly slow data rate over the faster data rate, however.
Old Jul 24, 2006 | 03:46 PM
BirdsOnly's Avatar
Car: Motorcycle
I am sorry I am new to the DIY prom stuff. But I thought the TBI and 85 TPI ($1F, $4D, $61) had the low baud rate, and the $6e and $32,$32b had the same higher baud rate. Am I wrong on that? are the pre-89 TPI all the low baud rate?
Thanks for the answers!
Old Jul 24, 2006 | 04:07 PM
Mangus's Avatar
Transmission: T5WC
$32 is 160 baud only. 6E is hybrid (160 baud and 8192). I had previously thought that $32B was 160 only, however others are saying that they can connect at 8192 using Datamaster. I am, however, unsure if Datamaster is doing something special to connect at the higher rate or if it is a genuine feature of $32B. I have not yet tested it myself.
M
Old Jul 24, 2006 | 05:16 PM
busta9876's Avatar
Engine: LMM Duramax
Transmission: 4L80E
So the datarate is all determined by the code? They are same part# computer, so just putting 6e on there will allow high baud rate communication???
Old Jul 24, 2006 | 05:31 PM
Mangus's Avatar
Transmission: T5WC
Yup!
my main reason was to be able to use Freescan to datalog. $6e was used in the 89 corvette, and is supported by freescan, where as $32 is not.
Cool. Freescan ships with source code, so you could add the necessary code to grab the 160 baud datastream and a definition to match as well.
J-money
Jan 4, 2019 09:45 AM
tonys91rs
Oct 10, 2015 03:31 PM
Billy Decker
Sep 4, 2015 03:46 PM
rudolphschenker
Sep 4, 2015 02:41 AM
