Need help with pocket programmer
Old Mar 21, 2001 | 02:46 PM
CanadianBeast's Avatar
Alright I just got my programmerand I pulled the eprom out of my jet chip used move to buffer and saved it, it worked. Then I used my eraser then plugged it back in to the PP and did a blank check, its says it's erased (ALL FF), I then load the buffer (arap 6e.bin) then try to program device and it says error or something like that and says it did not program. I have a 165 ecm using a 27c128 eprom. I read through the help files and everything seems to be in order, but it doesn't work.
Old Mar 21, 2001 | 02:58 PM
mike89z's Avatar
Car: 89 Iroc-Z
Engine: 355
Make sure that you are using the right program - - - I think its called fileprom.exe or something like that.
355 10:1 , AFR 190 heads, LT4 HOT cam w/ 1.6 roller rockers, complete Superram intake, 58mm BBK TB, 24# injectors, screens out of MAF, MAT relocated, March underdrive pulleys, Streetdampner, Crane HI-6 ignition, 160 thermostat, K&Ns, TES headers(Jet hot coated), Mufflex 4' cat back, B&M shift Kit, 2500 converter, and 3.27s.
I have been using it in windows, should I use the dos version?
Old Mar 21, 2001 | 07:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, try exiting to DOS and running the DOS version of fileprom. I've run into that problem when using flash proms with the pocket programmer and the windows version. If I exit to dos mode and then use fileprom it'll program the flash proms. I think its the way Windows controls the port, that causes the problem.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 21, 2001 | 09:42 PM
What voltage should I be programming at with a 27c128 eprom??
Old Mar 22, 2001 | 12:37 AM
Kevin91Z's Avatar
Doesnt it auto-select the voltage when you pick the PROM from the list?
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
86IROC112
Nov 7, 2015 06:50 AM
randy210
Oct 15, 2015 03:43 PM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Sep 21, 2015 10:24 AM
