Super AUJP converted to manual trans?
Old Jul 22, 2006 | 11:16 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I went thru this thread
https://www.thirdgen.org/forums/diy-...uper-aujp.html
and I apologize if I missed it, but I see talk of converting this bin to a manual trans but no record of someone doing it. I need the upper RPM tables as with our short tube runners we're hitting RPMs higher than 5400 and the air/fuel ratio is getting out of whack according to our wide band O2 sensor. I have the extended table in TunerPro RT but am told it only works on AUJP, not on an AXXD that I am using.
Thanks for any help.
Old Jul 22, 2006 | 11:54 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
The S_AUJP_V4 "should" have this working. It is a base AUJP but has some things to make it work with the manual.
A couple testers are indicating good results.
Still just a few issues to clean up before letting it go.
Mostly XDF, WB and ADS file issues that will make things confusing if not coordinated.
There are allot of cal items that also change with the MT and there looks to be an application to help port over the old bin settings to the new one.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
