New chip problems
Old Jul 23, 2006 | 10:07 AM
boredomkills's Avatar
Car: 1992 rs
Engine: 350 tbi
New chip problems
Ok i finally bought all the stuff to burn my own chips and i have been able to get in dialed decently for it being my first time doing this. But, since i have gotten all of my stuff and started to do this i have been having trouble with the check engine light coming on sometimes it flickers very fast(burned incorrectly or installed worng?) but the thing is i will put the chip in and it will run fine a few times for hours a few times for minutes then my check engine light will come on and off and flicker and go crazy. Everythign seems to be tight and well in place i am going crazy. Also i am using a g2 adapter a zif and 27sf512 chips.
Old Jul 23, 2006 | 10:31 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Have you tried bypassing the ZIF? Putting the chip directly into the G2 adapter? Also, is it programmed on the chip addressing from F000-FFFF?
Old Jul 23, 2006 | 02:13 PM
DM91RS's Avatar
Car: 91 RS
Mine did the same after my soldering in of socket to the board. (MY soldering skills sux)
It's probably loose somewhere.
Old Jul 23, 2006 | 07:40 PM
Car: 1992 rs
Engine: 350 tbi
yeah it basically acts like its loose right now i m rechecking all the solder joints because i had a friend try tweeking how it all sat in there and if he pushed it the right way it ran fine so i m gonan give it a try two of the joints looked like i forgot to solder(i was really happy to get all my stuff in).
Old Jul 23, 2006 | 08:41 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
If the prom is backwards on the 8746' ecms, i know for a fact that the ses light will flash real fast. Ask me how i know.
Old Jul 23, 2006 | 11:07 PM
Car: 1992 rs
Engine: 350 tbi
Tried bypassing the ziff and with or without it i have found that the only way it runs correctly is if i havfe a buddy push down on the chip or put a piece of duct tape on to push it down tight. What should i do?
Old Jul 24, 2006 | 01:16 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Clean up your solder joints (or de-solder and re-solder the assembly). Do all of this carefully.
Old Jul 24, 2006 | 04:40 PM
Car: 1992 rs
Engine: 350 tbi
I have gotten it all worked out thanks for the help.
Street Lethal
Apr 30, 2019 12:14 PM
inferno15
Aug 29, 2015 01:48 AM
ambainb
Aug 29, 2015 12:43 AM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
