870 to 7730
Old Apr 10, 2001 | 10:52 AM
Mojo's Avatar
870 to 7730
Does anyone know where I can find the information on converting from my 870 to a 7730? My MAF burnoff module ($900) just died, and I think that's reason enough. It seems like going to the 7730 would be way cheaper than DFI.
Old Apr 10, 2001 | 11:25 AM
Brent's Avatar
http://www.eecis.udel.edu/~davis/z28/
Old Apr 10, 2001 | 12:03 PM
Mojo's Avatar
I spent some time looking through this site, and it's a little vague on a couple of points. Does anyone know if the harness connectors are the same on the 870 as they are on the 7730? Will I just need to repin, or will I need completely new connectors?
Old Apr 12, 2001 | 07:54 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
The 28 and 32 pin black harness connectors
will fit into the '870, '165' and '730
ECMs, and just need repinning. The '730
has one additional 32pin (green) connector
that you would need to get to repin some
of your harness wires into.
mike
My Z28, ZZ4swap, TPI EPROMs
Old Apr 18, 2001 | 11:20 AM
Mojo's Avatar
Mike,
Is the green connector the same as the black connector? I have a couple of extra black connectors that I could use, but no green ones.
Old Apr 18, 2001 | 12:18 PM
leirch's Avatar
The green connector is different. I have one and it wont' fit into the black connectors slot. It has a different plug. Just go to a bone yard and pick one up. Hopefully they won't charge you an arm and a leg.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Apr 18, 2001 | 05:46 PM
cmarcho's Avatar
Mojo,
There are usually '85 Maf Burnoff Boxes on ebay for less than $50... but getting rid of the '870 is the better thing to do. Just thought I'd mention the used ones in case you need one to hold you over until you do the swap.
Craig M.
Old Apr 18, 2001 | 11:34 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You can use a yellow one from a six cyl. car too.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
BWilcox
Sep 20, 2015 12:19 PM
mddaniel
Sep 8, 2015 05:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
LBSZ28BLOWN
Jun 12, 2002 03:29 PM
HighHopes85
Jun 8, 2001 05:21 PM
