Knock at shift points???
Old Apr 16, 2001 | 10:11 PM
87Z-ya's Avatar
When making a data record at the track I see that my ecm is seeing knock when I shift. I speed shift the car @ around 6300 rpm. My decay rate is 3 deg per knock count and it pulls 6 deg out 1-2 shift, 3 deg 2-3 and none for 3-4. I think this might be false knock since I am speed shifting and it never sees knock any other time. Anyone have opinions?
87z 383,afr 190's, comp hyd roller(242/248-.540/.562,114 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, tremec 5spd, , 1,3/4" slp headers, speed pro bank to bank-wb02.
"Just remember children, no man can beat you once youv'e found the cliterous." 'chef'
Old Apr 16, 2001 | 11:39 PM
FORD Rustangs -R- Us's Avatar
speed shift as in power shift? i think of power shifting as 2 things (both are prolly wrong since im young )
1. flooring it, hitting clutch with gas still down and shifting as fast as u can with gas still down so u dont f-up ur engine
2. not using clutch which is death for ur engine/tranny
im assuming ur doin #1 since #2 is just plain retarded.
i know nothing about knock retard or prom burning..but from what ive read i think it would most likly be false because of the excessive gas and rpms when not using a load. thats just a guess tho and its late some im trying to waste time to get tired someone correct me plz, i posted out of a in the dark guess and to make sure #1 is the same as speed shifting
Old Apr 19, 2001 | 01:30 AM
Bob Wooten's Avatar
I have not noticed this in my toy but i have just recently come to notice this phenomenon in my Turbo Regal. I have a 78 TR, that has a "turbo Center". this is essentially a special "electronics package" that connects to a knock sensor on the manifold & the module in the HEI. this car does the same thing when it is between shifts that yours is going. the turbo center is pulling out the timing, but i could time this with a calendar not a stop watch. I can almost hear the electrons moving in those little tranistors, they move so slow.
in any case, not sure how this is working. about the only thing i can guess is that the motor is sensing that it is working less hard & that somehow is causing it to knock. I can not imagine that the engine vacuume is changing, not appreciably @ least. so i am just as stumped as you are.
in my car it is real knock. I can back the timing out 2 degs & it does not happen.
Bob Wooten
71 Camaro, 91 EFI
r71chevy@earthlink.net
www.r71camaro.homestead.com
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
masonta
Sep 1, 2015 06:40 PM
