Guys, i realize the vettes came with SD from 90-91 and they also came with the 350/6speed combo. Could i get a bin from a 90-91vette and use it in my 730/727 compatable computer? And if so, where can i get one? I looked briefly over the DIY-EFI ftp but was unable to find one(helps if i knew what i was looking for).
Thanks,
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Thanks,
Brendan
Do you want the 6 speed bin, or the auto bin? The auto bin is ANHT, and you can find it in the gmecm bin library. The 6 speed bin is out there in the same directory, but I'm too lazy to look it up right now.
408cid 1985 Corvette
http://www.mojosgarage.com
hahaha, I want the 6speed bin, i have a T5 and i NEED a manual bin to start with or atleast compare with. I found the auto bin but i don't know what the manuals bin is.
Kevin91Z
close
- Join DateJul 1999
- LocationOrange, SoCal
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1990 Pontiac Trans Am
- Engine355 TPI siamesed runners
- TransmissionTremec T56
- Axle/Gears12-Bolt 3.73
- Liked:26 Times in 22 Posts
I used a Corvette BIN in my Camaro for a while, and I would get Code 52 on the highway every time. The Corvette has an oil temp gauge that the Camaro doesnt have, and the computer would set the code that it couldnt find it. You'll need to turn off that code, because I dont know how. I switched back to a Camaro chip.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
I'll have to see if i can disable that oil temp switch problem. Can anybody confirm that the ANJF is the correct bin for the vette 6speed?
Quote:
<font face="Verdana, Arial" size="2">Originally posted by leirch:
</font>
My info shows it as an auto <font face="Verdana, Arial" size="2">Originally posted by leirch:
</font>
