OK, what's the secret??
Old Aug 3, 2006 | 07:54 AM
mk10842766's Avatar
I've swapped from a 6870 to a 7165, and I can't get any of the datalogging programs to connect. I've tried 3 different cables, all with the 10k resistor, but nothing connects! I can sometimes get winaldl to connect, but it only give me 5 or 6 pieces of info. Datamaster says it finds a GM160 pcm, but won't sync up. Does this mean that it finds a 160 baud datastream, or that it finds a 160 series pcm?? Tunerpro RT says it connects at 160, but gives really wierd, or no data, and won't connect at 8192.....so what's the secret to connecting???? this is driving me crazy!!!!
Old Aug 3, 2006 | 11:09 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
10,000 ohms is the secret.
Old Aug 3, 2006 | 11:13 AM
mk10842766's Avatar
10k and 10,000 ohms aren't the same??
Old Aug 3, 2006 | 11:35 AM
Mangus's Avatar
Transmission: T5WC
Nah, they are. Make sure you have a valid bin, are not running in limp-home mode, and that the data line is connected to pins E and M in your ALDL connector/cable.
Old Aug 3, 2006 | 09:16 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
A visual always helps.
Old Aug 3, 2006 | 09:21 PM
mk10842766's Avatar
AHHHH, so the data line has to go to BOTH E & M....I had to run new wires to my ALDL, and only ran a wire to M....does that make a difference??
Old Aug 4, 2006 | 11:29 AM
Mangus's Avatar
Transmission: T5WC
What matters is that whatever pin your data is sent to from the ECM side of the ALDL connector needs to match up to the data line on your interface cable when you're hooked up to the PC side of the ALDL connector.
Gta-Paladin
Dec 10, 2001 12:48 AM
daniel dekay
Dec 8, 2001 09:55 AM
Willie
Nov 5, 2001 12:37 PM
TomP
Oct 31, 2000 01:06 PM
