Connecting Tunerpro RT to the ALDL dash?
Old Aug 3, 2006 | 09:10 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
I cant get Tunerpro RT to connect to the Aldl dash? Nothing comes up. I have my AKM cable hooked up and it wont see it? Tunerpro see's my Ostrich and connects fine to that but I cant get the Aldl dash to work.
Old Aug 4, 2006 | 03:24 AM
JariV's Avatar
Car: Several, all with 8 cyl. Some bigger, some smaller
Engine: Ranging from L8 4,4 liter to over 9,2 liters full aluminum V config.
Transmission: Which one?
Wrong cable...
I had 3 or 4 different ones before the "light" came. Since then it has performed flawlessly, every time.
Old Aug 4, 2006 | 07:59 AM
Randy92Z's Avatar
Engine: Miniram 383
So my AKM cable works with Datamaster but not Tunerpro RT?? So what cable do I need then?
Old Aug 4, 2006 | 10:17 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Your AKM cable should work fine. I have one too.
What ADS? What ECM and code mask? More information is better than less information.
Old Aug 4, 2006 | 11:25 AM
Randy92Z's Avatar
Engine: Miniram 383
Im sorry Im using the 730 ECM and the 8D mask. As for the ADS, Im sorry for being new, I dont know what a ADS is?? I do understand that XDF files are bin definitions though. Thanks Mark.
Old Aug 4, 2006 | 11:27 AM
Mangus's Avatar
Transmission: T5WC
For 8D, use the 1227730.ads file included with the TunerPro download. You need to load the ADS file (this is the ALDL definition file) in order to connect to your vehicle. To open it, either drag and drop the ADS file into the TunerPro window, or hit F4 to bring up the ALDL setup window and then load the definition from that window.
Also, don't forget the help file (help menu).
M
Old Aug 4, 2006 | 11:29 AM
Randy92Z's Avatar
Engine: Miniram 383
Ah, I see said the blind man. Makes perfect sense now. Thanks again.
383cam
Sep 9, 2015 06:01 AM
Gunsbee
Sep 7, 2015 07:10 PM
Stryker412
Sep 7, 2015 09:11 AM
Ian Irvine
Sep 4, 2015 08:08 AM
andy74
Sep 3, 2015 08:41 AM
