165ecm and 29c256 Flash chip
Old May 4, 2001 | 08:35 AM
87IROC350's Avatar
Engine: 5.7
Well since no one else has taken the initiative I will. I programmed the flash chip last night with a 6E bin and have not had the chance to put it in the car yet. I will probably test it tonight and then post the results.
Later
87 Iroc 5.7, AFR190, SLP Cam(218/224), SLP 1 5/8 headers & cat back, Random CAT, SLP Runners, 48mm TB, custom chip(by me), Vigilante & Probuilt trans.
Old May 4, 2001 | 09:25 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I'm planning on doing my own test as soon as Dan Burk gets them and distributes mine to me...
Old May 4, 2001 | 09:43 AM
Scott 87 IROC-Z's Avatar
Car: 87 IROC-Z28
Engine: 377ci, Brodix Heads, Solid Roller c
Transmission: 700-R4 w/ Yank ST3500 Converter
I just received my programmer and 29C256 chips yesterday so I will be experimenting this weekend with it. I will also be converting to the 6E code.
87 IROC-Z 305 TPI gears, exhaust, converter
14.70 at 94.1 mph
Minirammed 377 for spring
Old May 4, 2001 | 01:48 PM
CanadianBeast's Avatar
I just asked this question in your other thread, I didn't notice this post are you programing the bin to both halves of the 29c256 or just one? Which side? Could you explain in detail how you do this, as I said in the other post I'm sick of my UV eraser and would love to use flash programing.
Old May 4, 2001 | 01:57 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I believe you have to use the upper half, but for simplicity just concatenate the bin twice into a 32K bin. This is what I plan to do with Karl (aka Hunter Motorsports) comes to my place on the Victoria Day long weekend and experiment with this.
There is absolutely NO REASON why this shouldn't work. If no one gets it to work before the Victoria Day weekend, I will tell you how to make it work.
Old May 4, 2001 | 03:13 PM
89vette's Avatar
Does the pocket programmer flash the Eprom? I'm tired of my UV erasor also.
Let us know your results. Did you solder a zif socket on the memcal?
Old May 4, 2001 | 05:25 PM
93ND500's Avatar
I got a 29C256 loaded with the arap.bin. I plan testing it this weekend. I'll keep everyone posted on how it does.
Old May 14, 2001 | 11:33 PM
93ND500's Avatar
Well I was finally able to test the 29C256 chip this weekend. So far, so good. I programmed two different chips. One with a doubled up bin, and the other with the bin loaded into the upper half of the chip. The doubled up chip did not work, I'll find out why later. The one loaded into the upper half is working fine. I used a modified ARAP.bin for the testing(no vats,egr,ZZ4).
Test car info: Not my car, it belongs to the son of one of the guys I work with.
1987 IROC (i think)
355 ci.
500/480 roller cam.
ported heads.
headers, gutted cat, flowmaster muffler.
2200 converter, shift kit.
adj fpr, 160 t-stat, MSD ign.
all "free" mods.
Linson
Oct 24, 2025 02:00 PM
RS Reaper
Oct 17, 2018 07:52 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
lewandom
Oct 1, 2015 08:15 AM
