Calculating VE at peak horsepower
Saw on a website how to caclulate VE if you know the peak horsepower and RPM. My motor on a dyno made 400HP at 5500 RPM. So that's
(400*792001.6)/(29.92*10.75*396*5500)=.45
Where 29.92 is pressure (for arguments sake)
10.75 is compression
396 is cubic inches
5500 is RPM at peak HP
Then I calculate theoretical CFM
396*5500/3464 = 628 CFM
Then I calculate Actual CFM
(396*5500*.45)/3464 = 283 CFM
So if I read this right, my engine only needs 283 CFM of air to make 400 horsepower at 5500 RPM?
What is the normal VE of an EFI small block. I feel as though I should be making more like 480HP at 5500 RPM.
What gives?
396 is cubic inches
What gives?
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by 89vette:
396 is cubic inches
What gives? </font>
396 is cubic inches
What gives? </font>
Unless you doing the measuring during the test your just guessing and the numbers may or maynot make sense.
If you asking about air consumption, you can make 1 HP/1.3 CFM of air.
Just trust the stop watch, and tune to what the engine wants
Elephantismo
Feb 13, 2019 12:51 AM
dbrochard
Sep 25, 2015 04:56 PM
283, 7920016, air, calculate, calculating, calculation, cfm, engine, free, horsepower, motor, motors, peak, rpm, theoretical, ve
