VSS I/O
Old Aug 5, 2006 | 08:53 PM
ryan.h's Avatar
VSS I/O
I know there's a flag you can set to select a magnetic vs optical VSS. Now as I understand it, the 4000 and 2000 ppm outputs from the ECM are open collectors that get grounded for each pulse. Is there any flags you can set to turn those into 0-5V square waves?
Old Aug 6, 2006 | 12:32 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I'm assuming you are refferring to B11, B12 and C1 outputs.
I thought thats what they are (Sq waves). I don't know for sure.
Why do you think they are something else?
Old Aug 6, 2006 | 11:28 PM
Z69's Avatar
Z69
Have a look at the schematics on ludis.
Old Aug 7, 2006 | 09:43 AM
ryan.h's Avatar
I think the outputs go through 3 state inverters. Unless my ECM is broken, I have never seen 5 volts on any of those outputs (as shown in the schematic - normal inverters). They are always ground switches.
So I'm guessing that means no way to change it via software.
Old Aug 7, 2006 | 11:45 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
What computer are you using, what kind of car?
Old Aug 7, 2006 | 11:52 AM
ryan.h's Avatar
7730. any.
Old Aug 7, 2006 | 12:41 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
If all you want to do is get a 0-5 volt swing, just grab the +5reference from the ECM, and stick a resistor from there to the signal output, say 4.7k or 10k. easy enough. If you want it to be 0-12v, wire it to +12v out of the ecm. (use these becuase they will be filtered nicely out of the ecm (or stick a capacitor or two at the voltage as well (.1uf, 1uf in parallel work great). No need for any software, you just need to complete the circuit.
this applies for any of the open collector outputs.
Old Aug 7, 2006 | 02:35 PM
ryan.h's Avatar
yeah, I was hoping I could do it via software. Oh well... Thanks guys
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
