swapped ECM and burned a few chips
Old Jun 3, 2001 | 08:22 PM
james_fearn's Avatar
I swapped my 870 ECM to a 165. It only took a few hours. I checked as I went and rechecked everything at least 3 times. Everything went smooth with the only error being the inverted fan think which I forgot to do on my first chip. I started the vehicle (after disconnecting the cold start injector) with a APYM from an 89 305/A4 (VATS disabled) for use later as a back-up chip. Besides the fan thing it worked well. I then burned an ARAP bin corrected for the injector size, VATS, and desired idle speed.
Thanks for all the help and info.
James
1985 Z-28 305 TPI 223,000+ mi., Original Eng.,T-Tops,Blue/Grey
STB,SFC,GW "wonderbar",145 Speedo
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
djmarch
Aug 19, 2015 12:07 PM
Exxon Limited
Aug 9, 2015 08:13 PM
