Pocket programmer?
Old Jun 19, 2001 | 08:04 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Pocket programmer?
I can't get mine to work, I've been using the DOS software and it says it can program, but when I do a blank eprom check it says the prom is erased. What gives?? At first the software didn't even find it with the DOS version (funny how the windows did though). The DOS says the prom is erased, but the windows says it isn't. I'm using AM27C128 -120DC 0044MSM 12.75V and I choose #10 when it comes time to select the chip.
I load the buffer from disk (14), then I program eprom from buffer(2), then I do a blank eprom check(1).. and it says it is erased! Does it sound like I'm doing something wrong.
Old Jun 20, 2001 | 11:26 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Have you called and talked with Xtronics yet?
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Jun 20, 2001 | 01:26 PM
Mojo's Avatar
Mine is funky too. I have to use Windows to erase, and Dos to program. It fails doing it any other way.
408cid 1985 Corvette
http://www.mojosgarage.com
Old Jun 20, 2001 | 02:24 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
There were some posts recently of people having problems getting the Flash Prom AT29C256 to work properly with the Pocket Programmer.
It turns out that certain computers need to have certain "drivers" disabled in the Config.sys and autoexec.bat.
Karl from Xtronics posted a link to FAQ's on the Pocket Programmer that helped most people overcome these difficulties. Check some of the older posts for these. I think you will find your answer in there.
YES, some machines DO need to be tweaked to get the Pocket Programmer to work properly. I have found DOS always works when you set up your computer properly. But I was never able to get the Windows Version to work on my older, slower (with less memory) W95 machine which I use for PROM burning.
I got the Windows version to work on my larger, faster (and more memory) W98SE notebook....but I don't use it for PROM burning. So there are some "machine dependencies" for the Pocket Programmer. But the DOS version should ALWAYS work when your computer is set properly.
Check your Parellel Port Setting in your BIOS to ensure it is in "standard" mode. Bi-directional seems to cause some problems on some machines.
Old Jun 20, 2001 | 08:40 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I have not had any problems programming with my Pocket Programmer. I use Win98, and didn't change any settings. I never tried it from DOS. My PC has an AMD 475 chip with 256kRam.
You may want to try progamming those 27C128 chips at 21volts. That's what I have to use to get it to work. Most chips do take the 12.75, but the manual suggests trying higher levels if the chip won't burn at the lower voltage.
Best ET 14.413 @95.57 without
pulling valve covers or manifolds.
Also with stock 2.77 rear end!!!
Old Jun 20, 2001 | 11:27 PM
james_fearn's Avatar
I've never had any problems either. I have programmed only in Win98 SE for both 27C128 and 29C256. No problems.
James
1985 Z-28 305 TPI
165 ECM,STB,SFC,GW "wonderbar"
Old Jun 21, 2001 | 10:21 PM
slowTA's Avatar
Car: '88 Formula
I called them earlier today and they were pretty stumped, all I was really able to do was try a different computer. I tried and no difference. Now to make things even more unusual I read the original chip and then verified it back to the same chip without removing it from the programmer... it didn't verify!! I simply read it then tried to verify... shouldn't it verify, or am I way to stupid to make this thing work??
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
86IROC112
Nov 7, 2015 06:50 AM
randy210
Oct 15, 2015 03:43 PM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Sep 21, 2015 10:24 AM
