Changes for 4.10 gears/89Z305tpi-m5...bin
Old Jun 22, 2001 | 12:55 PM
jfulford's Avatar
Hello. I've got an 89 T/A, 305 TPI that I have done some minor mods to, as well as just adding 4.10 gears. I'm using the 89Z305*.bin file with the 89v4.ecu(Winbin).
Are there any variables/array/flags with the above bin/ecu that I can take advantage of using 4.10's?
I'm using a pocket programmer with 27C128's.
Would Tunercat be any better for this(ie, more options)?
thanx
jeff
jlfulfor@icon-stl.net
"Drop that coconut, Gilligan!"
jfulford1@earthlink.net
Old Jun 22, 2001 | 10:37 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by jfulford:
thanx
jeff
</font>
With the change in gearing you'll be able to add some timing faster, and enrichen the fuel some. THOU, there are some exceptions to that.
With the 4.1s the engine will never see as much of a load as it did before, so making heat maybe a problem. By heat I mean HP in the combustion chamber.
It's easy to over gear a car and have it slow down, because it revs so easily that it can't make any serious heat. It heat that is converted into mechanical energy, ie HP
Old Jun 23, 2001 | 08:05 PM
jfulford's Avatar
Thanx for the info! Gives me a starting point to work from/on. Much, much to learn.
Building them is easy--getting them to run right is rocket science!
jeff
89 T/A 305, T-5, 4.11's, minor mods and free mods.
6speedIROC
16
Mar 15, 2023 08:33 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
S10K20
Oct 7, 2015 06:45 PM
TexasMaro
Sep 15, 2015 06:50 PM
6speedIROC
Sep 13, 2015 01:29 PM
