The OTHER chips
Old Jun 25, 2001 | 03:12 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The OTHER chips
On the CAL-PAK I notice, as I hope everyone else has, that there are two other chips. Some even have a third Chip, similar to TRAXIONs pix. I was wondering if anyone knows what the other 2 chips are used for. Limp-Home and what? I happen to have a hpyerchip cal-pak without the other chips.
Thoughts?
87 Formula Yellow/Black
Engine & Transmission
.040 over 5.0 converted to TPI, 9.5:1 Compression, SLP Cam Dur 206/212, Lift 480/487, Cent Line 112, SLP headers, SLP cat-back exhaust, K&N Airfilter, Modified Stock cold air intake, Ported & polished Stock TPI intake, Holley Adjustable Fuel Press regulator, AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit, Aluminum Driveshaft, 3.73 Posi gear
Suspension & Brakes:
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Hotchkis strut tower brace, South side machine frame connectors, Custom reinforced control arms and pan hard bar.
Interior:
Custom Leather interior, CUSTOM Yellow Gauge Faces, Kenwood Receiver, Pioneer Speakers, Kicker Substations, Kenwood 10 Disk Changer, Pioneer Amp.
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Jun 25, 2001 | 03:38 PM
gravitar's Avatar
So you're saying that your aftermarket memcal doesn't have the other twe chips, and your car runs?!
The one at the far end is a resistor network that calibrates the backup fuel (limp-home) system. It is application specific, at least as far as the number of cylinders in the engine.
The one in the middle is a filter for the ignition system's ESC module. The 7730 uses a white circuit board attached to the memcal, which takes the place of the underhood knock sensor "filter" that was used with earlier ECMs.
Old Jun 25, 2001 | 06:09 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by gravitar:
</font>
While they are chips, they are just convenient packaging for resistors, they can use laser cut resistors, and when you're doing them by the million that's the way to go. On the protype memcals, there are resistors and a few dodads soldered in place. So you don't have to actually have chips in there just the right resistors.
BTW, laser cutting the resistors can make them very accurate, inlike carbon types.
Old Jun 26, 2001 | 07:59 AM
okfoz's Avatar
One reason I was actually asking, is I had a friend give me a Cal-Pak from a 89-91 3800 Engine, I thought about pulling the Chip and making it a backup. I am not sure it would work since one of them is a limp home mode. I have this thought of playing with fire if I tried it.
John
Old Jun 26, 2001 | 09:09 AM
gravitar's Avatar
I was thinking about using a '91 S-10 memcal as an "experimental" part. I'm extremely reluctant to modify the stock memcal, as I appreciate my car being able to run properly
In the GMECM archives, I remember someone telling which pins on the netres set the cylinder count. (It was probably Grumpy!) If you put the correct resistor value across these pins, it'll at least let you run, albeit without proper backup fuel capability.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
