I Did it :) Question with DIACOM & TCC
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Well, my FIRST adventure in chip programming was a success, The car runs, and it drives better than before. Not saying much since all I did was take the 305 ARAP Bin that was supplied by zaphodb and did a little tweeking.
This MIGHT not be a big thing for you, but cinsider that I am using the 29C256 chips I am geeked that I got it all to work.
Enuf grinning..
Got a question...lemme set some background.
SINCE I have an 87 car I was ignorent enough not to switch my DIACOM, and I noticed that it was not registering the TCC (Torque Convertor Clutch) Lockup. When I thought about it for a few seconds, I remembered that the ARAP chip was for an 89.
Sooooo, I changed my VIN to an 89, and there was NO TCC Lockup, but a 3rd Gear / OD Switch, that would change fomr off to on. All the switches seemed to be operating as far as the ECM was concerne. So am I ok, or is there something I am missing?
In Short, how would I know if I have a TCC lockup with DIACOM, since the 89 setup does not offer that option???
John
87 Formula Yellow/Black
Engine & Transmission
.040 over 5.0 converted to TPI, 9.5:1 Compression, SLP Cam Dur 206/212, Lift 480/487, Cent Line 112, SLP headers, SLP cat-back exhaust, K&N Airfilter, Modified Stock cold air intake, Ported & polished Stock TPI intake, Holley Adjustable Fuel Press regulator, AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit, Aluminum Driveshaft, 3.73 Posi gear
Suspension & Brakes:
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Hotchkis strut tower brace, South side machine frame connectors, Custom reinforced control arms and pan hard bar.
Interior:
Custom Leather interior, CUSTOM Yellow Gauge Faces, Kenwood Receiver, Pioneer Speakers, Kicker Substations, Kenwood 10 Disk Changer, Pioneer Amp.
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Enuf grinning..
John
Interior:
83 Camaro (Parts)
83 T/A (parts)
Not an answer to your question, but since you're mentioning Zaphod's BINs..
Did GM really offer 305 and 350 varieties of ARAP, or was one of them user-modified from the other? just curious..
[This message has been edited by gravitar (edited June 28, 2001).]
NO, the ARAP was for a 350, it was just modified to work in the 305, the injector flow rate was set down to 19.5, I honestly dont know what else was changed, but it worked GREAT in my 305 (312).
John
John
Car: Death Mobile
Engine: 666 c.i.
There is NO cylinder displacement change necessary to make the ARAP work with a 305. MAF has no such requirement, only SD does. The only differences needed for the ARAP is Manual versus Automatic, and the Injector Flow Constant. The rest (spark, highway mode AF ratios, TCC locking speed) are just tweaks that are based on personal preferences.
[This message has been edited by Glenn91L98GTA (edited June 28, 2001).]
I started to think, SINCE the ARAP was originally for a 350. From 86/87-92 all 350's were an Auto from GM, and there was no exceptions. Therefore this means that it came with an AUTO, and therefore should work fine...
Car: Death Mobile
Engine: 666 c.i.
I have tried the ARAP BIN on both autos and standards...and it works fine. About the only thing that some people like to alter is the spark advance...it is quite aggressive (47*) at part throttle on the ARAP.
You should get the modified 6E ecu file from Zaphod that allows you to tweak the ARAP to your own personal preferences or get 6EX.TDF from TunerCat (if those mods have not been incorporated in the standard 6E yet). It is more important to mod the bin to YOUR car and your personal preferences.
I bought the $6E & the $32B for Tunercat a few days ago, thats what I was using, the $6E that is.
Is that what your thinking???
John
John
Car: Death Mobile
Engine: 666 c.i.
Contact TunerCat and request the 6EX.TDF if TunerCat has not incorporated the changes in the 6EX.TDF into the 6E.TDF. It will make tuning the ARAP.BIN a bit easier.
