Starting point for 350 TPI
Old Jun 29, 2001 | 06:07 AM
Tomcat's Avatar
Can anyone recommend a good bin to start off with for a 350 Tuned port using a 1227165 ecu
It was originally a 305 but I have put together a new combo With bigger 775 injectors and alloy heads .
I upped the original fuel constant to get it started but would like to start with a known good calibration (factory) before I start to do some tuning.
Are the later $6E better than the $32 I am currently using - I assume I just unplug the cold start injector ?
Daniel
Old Jun 29, 2001 | 07:06 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Go with the ARAP bin found in quite a few webpages nowadays. Do a search on this board for ARAP and you'll find plenty of references to it. Yep, just unplug the cold-start injector, or remove it and fill in the holes with a block-off kit. The $6E is better since it it much-more defined, and there's a great WinBin .ecu file for it now.
Greg Westphal
'87 IROC 355TPI/A4
Old Jun 29, 2001 | 08:01 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by Tomcat:
Daniel
</font>
As Greg suggested, try the ARAP bin, it's probably the best starting point.
Here's some links for you to start with. This ARAP bin is totally original, no modifications done to it. I'd suggest you just change the injector constant and the Fan operation flag (Should be N/O).
Then get Craigs program and monitor the ALDL data to see what else you need to change...
http://www.area51.org.il/~zaphodb/gmecm/ARAP.bin
http://www.area51.org.il/~zaphodb/gmecm/WinBin14.zip
http://www.area51.org.il/~zaphodb/gmecm/6Ev006.zip
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
Old Jun 29, 2001 | 08:53 PM
Tomcat's Avatar
Thanks guys I will try the ARAPbin . Was that originally a 350 bin ? if so I will not need to change the injector constant as the injectors I have are 350 injectors ?
Old Jun 29, 2001 | 09:03 PM
Engine: 385 HSR
Yep, it was for a 350, so you won't need to change the injector constant if you have the stock-size 22lb injectors. Enjoy!
Greg Westphal
'87 IROC 355TPI/A4
Old Jul 2, 2001 | 04:25 PM
kevinc's Avatar
Car: 1982 Z28
Things to watch for on the ARAP bin are below. All are available in WinBin with the latest config file which I believe somebody already posted a link to.
VATS is enabled. If you're running an '88 or older F-body you probably don't have VATS. Car won't start until you disable it.
Fan switch logic is reversed. The ECM enables the fan it controls whenever you turn the air conditioning on. ARAP thinks AC is on when the line pressure switch is open...your F-body switch is reversed, and closes when AC is on.
ARAP has a **LOT** of spark advance. It was configured for a hi-po engine running aluminum heads being driven by somebody who uses 93-octane gas.
-Kevin
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
theshackle
Mar 5, 2017 06:37 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
