ALDL connector
Old May 27, 2001 | 05:28 PM
JJ IROC's Avatar
ALDL connector
Do you any of you know a good place to get a ALDL connector. I was planning on making my own cable for the lap top and only thing I can't find so far is the ALDL connector. If you know where to get one please supply a part number if at all possible. Thanks.
JJ IROC
1987 Camaro IROC Z-28 383ci. TPI 6 Speed T-56 black
My Car
jjiroc@alijas.net
Old May 27, 2001 | 08:13 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Check out the Auto Xray 20110 cable. It'll set you back $20-30 but it's what you're looking for.
See it at OnTool <A HREF="http://www.ontool.com/store/product/5045">http://www.ontool.com/store/product/5045</A> for $24.95 or <A HREF="http://www.summitracing.com/">Summit</A> for $27.99 (search for Summit part AXY-20110).
Old Jul 20, 2001 | 01:22 PM
BLOWN85/TA's Avatar
Does this cable just have the proper end to plug into the ALDL port and not the connection for the laptop? I need a cable that will work with Craigs software(for getting started), that's why I am asking.
Old Jul 20, 2001 | 01:29 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Yes, the auto x-ray cable won't work on a PC; if you want a complete cable to work with Craig's software, you can buy one pre-made from <A HREF="http://www.akmcables.com/">AKM Cables</A>
Just specify what you're going to be using it with and he'll hook you up with the right cable.
Old Jul 20, 2001 | 05:35 PM
BLOWN85/TA's Avatar
Will a cable that works with Craigs software work with any other software?
Old Jul 21, 2001 | 06:29 PM
JPrevost's Avatar
Car: 91 Red Sled
No, some use the parallel port, others use serial (com ports). Most of the newer software uses the serial cables. The only ones that use parallel port as the interface are: Diacom, Ease (like diacom), and turbolink.
, Jon (350 TBI!)
91 Red My website
Old Mar 12, 2002 | 01:33 AM
gonzo350's Avatar
will the summit cable work with Craigs software....or do i have to spend the $100 for an AKM cable?
Old Mar 12, 2002 | 01:34 AM
gonzo350's Avatar
addtl info from my last post....will the summit cable work with craigs software running on my laptop
Old Mar 12, 2002 | 09:09 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Is there a place where I can buy just the ALDL plastic connector. I have searched the web quite a bit and still can't find them. I have been using ground down electrical spades. It would be nice to put a plug on the end of my hacked/homebuilt thing. Or I could put in a DB9 on the car too. Nah, the ALDL 12 pin is better.
Thanks,
J
Old Mar 16, 2002 | 11:46 PM
Eric91Z's Avatar
Car: 2004 Mercury Marauder
Engine: 4.6L DOHC
Transmission: 4R75
Axle/Gears: 4.10 gears/8.8 rear
When using Diacom, what pins on the ALDL connector need to connect to the cable? Is it the E and Ground pins? Or does it need more?
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
