problem with winbin
Old Jul 29, 2001 | 12:20 PM
v8power's Avatar
problem with winbin
When I load up a bin using WinBin and under the values tab every time i select the rev limit to cut fuel i get a run time error 11 divide by zero error
is this the program or my bin file?
thanks
Old Jul 29, 2001 | 02:55 PM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by v8power:
thanks
</font>
Winbin has a problem with 16 bit values, you have to edit that value with a hex editor, and then load the file in Wnbin and recaclculate the checksum. Winbin will, however show you the correct value when you look at the limiter....
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
Old Jul 29, 2001 | 04:42 PM
v8power's Avatar
I cant even look at the value in winbin
and what address is that byte located at?
Objects in mirror are more stable than they appear
www.members.home.com/v8power
Old Jul 30, 2001 | 12:42 AM
ZaphodB's Avatar
</font>
What version of the .ecu file are you using?
I'll email you the latest one....
Old Jul 30, 2001 | 01:26 AM
v8power's Avatar
32Bv001.ecu
v8power@home.com
4BBL to TPI in the works
86 350 5spd custom made weld in subframe
Old Jul 30, 2001 | 02:56 AM
ZaphodB's Avatar
32Bv001.ecu
v8power@home.com
</font>
That should work, I just looked at a $32B bin with that ecu file. Are you sure that the bin you are trying to look at is not actually a $32 bin?
Old Jul 30, 2001 | 10:16 AM
v8power's Avatar
I am new at this so it quite possible
how do you tell them apart?
Old Jul 30, 2001 | 01:53 PM
ZaphodB's Avatar
</font>
The easiest way to tell them apart is to try to load the bin in the demo version of TunerCat, and it will tell you which TDF file it would require. But I think that $32 is the most likely one for it to be.....
Old May 9, 2002 | 04:07 PM
Frank88's Avatar
Hi,
I know this is an old post, but I'm having the same trouble. Anyone know the address where these are located?
thanks
johnfamily@bigfoot.com
Old May 10, 2002 | 07:42 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
thanks
Yep, you can find the .ecu files at:
http://www.area51.org.il/~zaphodb/gmecm/
Old May 11, 2002 | 08:34 PM
Frank88's Avatar
Thanks Greg.
I had a major brain-fart with that one! Of course it's in the .ecu file! I'm going to try winhex to edit the value directly. (Not like I'd ever be able to rev to 10K rpm or whatever it is anyway!) Is there a better editor to use?
(edit)
I just went in with Winhex and changed the values to something more realistic (~6K rpm). Really very simple to do! Now I hopefully have a realistic rev limiter. Winhex is a very nice tool.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
