Moates software locking up??
Old Jul 13, 2001 | 11:52 PM
Steve10's Avatar
Anyone have problems with the software locking up. The first time I hooked it up it linked and I went for a drive. I logged one run, then on the second run I noticed it locked up at the end of the run. I still got some data, so I pulled up the .csv file and pondered for a little. Decided to go hook it up and take more data. It linked up okay, but after about 2 min. of driving I looked over and the page 4 #'s were locked up. I didn't even get a chance to log anything. Any ideas?
'87 Formula WS6 - ZZ4 Crate TPI, ported heads, LT4 hot cam, 1.6RR, Accel runners, Accel lower, ported plenum, Edelbrock 58mm TB, pulleys, SLP cold air, headers and full exhaust, gutted cat, Walbro 255, Koni yellows, aftermarket panhard & LCA's.
Old Jul 14, 2001 | 12:33 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
FWIW, try borrowing an older/other laptop... I've had problems with some of the newer hardware thats out there. When mine locked up, pressing any of the keys would unlock it and cause it to start logging again.
Old Jul 15, 2001 | 10:18 PM
86atc250r's Avatar
It's not his software locking up if it's doing what I think it is... It's actually the communication from the 165 ECM itself.
Mine does this periodically, sometimes frustratingly often, sometimes there's REALLY long stretches between times.
I've talked to Craig and others about this, it seems common & no one has an explanation yet.
I've verified it's not Craig's program by attempting to link up with other programs, re-linking with Craig's software, and just by monitoring the datastream itself and there's just nothing there after it happens. I've also experienced this with Freescan.
Usually if you shut off the ignition for about 15 seconds, leave your laptop on with Craig's software up and running, then turn the ignition back on, it will take back off right where it left off. Which also goes along with the ECM being "locked up" vs the software.
Gabe
[This message has been edited by 86atc250r (edited July 15, 2001).]
Old Jul 16, 2001 | 10:39 AM
Engine: 5.7L TPI
<font face="Verdana, Arial" size="2">Originally posted by 86atc250r:
</font>
Allow me ruin that theory for you. I am using a 730.
Old Jul 16, 2001 | 11:11 AM
Steve10's Avatar
I've successfully logged data a few times over the weekend with no further lockup. This is a great scan tool and I can live with it every now and then. Especially when its free!
Old Jul 16, 2001 | 11:52 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I also have been having lock up (no streaming data from the car/ECM) issues with Craig's software. I have not tried restarting the car while leaving the laptop connected but I have tried restarting the laptop multiple times and running the scantool (e6.exe) from dos and Win98SE but it remains locked up (not receiving streaming data from the car). So my observations support the theory that it is the car/ECM that stops communicating.
This is still an issue that can be resolved somehow as a Tech1 or Tech1a has no problems staying linked up and receiving data. Is everyone here using an AKM cable? If so, this could be a cable issue.
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, K+N cone, AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, ARAP, 2300 stall, Hotchkis STB.
Old Jul 17, 2001 | 02:42 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I'd love to hear about a solution here, this has been a real PITA for me, too.
Old Jul 17, 2001 | 07:42 AM
Steve10's Avatar
AKM here.
Old Jul 17, 2001 | 09:14 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I'm also using an akm cable but have had no lockups. data point.
Old Jul 17, 2001 | 10:29 AM
Matt87GTA's Avatar
I just have to say thanks to Craig here since we are discussing his software. Even with a few little PITAs like this, we are very lucky to have a guy like Craig who is willing to GIVE us all his program for free. I know I have thanked you before, Craig, but thanks again.....
I was just thinking, what if a guy could get a hold of the code from a Tech1 ........
[This message has been edited by Matt87GTA (edited July 17, 2001).]
Old Jul 19, 2001 | 03:31 AM
whiterocz's Avatar
i have found that i get occasional interuptions in data sent to my laptop when running the program. all i have to do is hit a button and the program starts reading again. i just press shift since it doesnt do anything. its like the program goes to sleep and is woke up when i press a button.
Old Jul 22, 2001 | 09:14 AM
Sarkee's Avatar
<font face="Verdana, Arial" size="2">Originally posted by whiterocz:
all i have to do is hit a button and the program starts reading again. i just press shift since it doesnt do anything. its like the program goes to sleep and is woke up when i press a button.</font>
This sounds like a power management problem. Make sure any/all power management (suspend, etc) is disabled in BIOS as well as in (under Windows) Device Manager/System Devices, and Power Management (Always On, Never, Never, Never).
Old Jul 22, 2001 | 02:30 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I tried to use E6 today to log a no start problem I'm having but was having a lot of problems. I hit L for log and the software said that it was logging, but when I quit, the only thing in the log for 4 out of 5 runs was the header line.
I tried both abbreviated and full logging with no success. Only one run it appeared to log
Craig?
Old Jul 31, 2001 | 04:57 PM
Matt87GTA's Avatar
Has anybody gotten anywhere with this? I have been busy with some other mods lately and haven't been able to play with my EPROM tuning stuff. I am going to disable my power management stuff tonight and give her a whirl if the weather is good.......
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, BBK 52mm TB, Edelbrock TES, gutted Cat, Flowmaster, CAI w/K+N cone, AFPR, TB bypass, !AIR, !A/C, !EVAP, ARAP, 2300 stall, Alum. Driveshaft, Hotchkis STB, '99 Camaro seats.
Coming Soon!!: Fourth gen 3.42:1 rear, Spohn LCAs and Panhard.
Old Aug 1, 2001 | 03:26 PM
Matt87GTA's Avatar
Well I disabled all of my power management stuff in Windoze and in the BIOS of my laptop (Toshiba w/ Pent 75, 40 MB RAM). I thought everything was fixed at first. I was runing the car in the garage at idle and I was getting streaming data perfectly for quite a while. So I packed up and took her out for a field test. I got about a mile from my house and it stopped receiving data from the car. I tried restarting and running it from command line and from windoze but neither one worked. I am not sure, but I think it is really toast this time. I only tried it a few times since it takes my laptop about two full trips around the sun to boot up, but it would not even link up with the ECM after it stopped reading. Any ideas people??????????
Old Aug 1, 2001 | 03:34 PM
CheezX's Avatar
Have you guys checked the actual connections? I made my own MAX233 interface and hooked it up with paper clips. If I moved the cable around with my foot the data would stop. Check to make sure all the connections are stable and that the interface is getting enough power all the time.
'90 Red Formula Firebird
305 TPI 5-speed UBC Sports Car Club
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
