ECM Swap from Auto to Manual trans
Old Jul 27, 2001 | 07:17 AM
RS91's Avatar
Is it possible to swap ECM comming from a 91 RS Camaro that has a Auto trans to 91 RS Camaro that has Manual trans...
Old Jul 27, 2001 | 07:37 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by RS91:
</font>
So long as you switch the prom/memcal from one to the other.
Old Jul 27, 2001 | 09:36 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Also, if the two cars have the same engine (or type of engine) then swapping the ECM is okay...in fact, only the Memcal is different between the two.
But if one is a TBI V8 and the other is a V6, then no, you can't swap the ECM as they are different.
And TPI uses it's own ECM again.
Old Jul 27, 2001 | 02:36 PM
leirch's Avatar
Good thing is, The TBI doesn't have a memcal. So theorectically(sp?) all you would need is the PROM itself. If you pull the cover on your current ECM you will see the removable chip(PROM). All you need is one from the SAME engine but for a manual.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Jul 27, 2001 | 08:05 PM
RS91's Avatar
Thanks for all the Information..
But I'm I bit confuse...What is PROM AND MEMCAL? Can I just swap ECM without worying about the PROM and MEMCAL?
Again Thanks for all the help...
Old Jul 29, 2001 | 10:25 PM
RS91's Avatar
Yes!!!! I was able to Swap it without a Problem. I even swaped the Injector at that to worked....
Again thanks for all the help
Old Aug 1, 2001 | 03:09 PM
sunbound's Avatar
Car: 1987 IROC-Z
i just kept the stock prom from my 87 iroc, that had a 305 in it, and swapped the computer from the 90 i took the 350 from. the 87 was a manual, and the 90 was a automatic.... works fine for me... no problems yett....
Old Aug 1, 2001 | 05:08 PM
RS91's Avatar
Thanks for all the help and information...
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
Leggman1
Aug 6, 2015 04:15 AM
