Is this the stock EPROM???????
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
I just bought a used TPI system complete with computer....I opened up the computer to check everything out...and see what i was getting into when I started to get in the prom burning scene....I see the chip and everything...but theres a sticker on it that says "Jet Perf Prod. Part# 19112-S. Off road only!!!" It came from a 1991 Transam 305. First of all....what can you tell me about this chip?? Second...is this the famous #3 option in the prom burning introduction article?? The chip is facing up...and then theres a brown and blue thing on the side of it....never seen a stock computer...and the images in that article arent working....a little help please...thanks
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cats Coming
More to come.
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by mult68:
</font>
</font>
This should be a speed density setup since it's from a '91 TransAm, so the image below is most likely to be the right one to start with. Since it's a newer than '88 car it came from, you will have to disable VATS or you will never get it to fire.
ftp://ftp.diy-efi.org/pub/gmecm/bin_lib/1227730%20727%2001%20A1%203E%2046%2051%2055%206B%2088%208D%2096%20D8/8D%205.0%205.7s/AUJP%208D.bin
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
[This message has been edited by ZaphodB (edited August 02, 2001).]
Engine: 305 TBI
I was told it was easy to wire up the existing VATS in my car to the new ECM...and everything would work including VATS...true?
I was told it was easy to wire up the existing VATS in my car to the new ECM...and everything would work including VATS...true?</font>
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Yes, it is option #3. You have a MemCal adapter and the Brown and Blue thing on the side is the actual MemCal.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Tim
Genopsyde
Oct 7, 2015 08:35 PM
