5-speed vs 6-speed
Old Sep 6, 2001 | 02:14 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
5-speed vs 6-speed
I'm curious what is different on a Camaro 5-speed prom vs a Corvette 6-speed prom. So far I havent seen anything in the TunerCat TDF file, its just auto or manual. When I put in my T56 is there a setting in the prom I should change?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 6, 2001 | 08:55 AM
kevinc's Avatar
Car: 1982 Z28
I was looking at this last night, and noticed with the "D" version of the $6E TDF it's looking for the manual trans bit in the wrong location. I checked with a hex editor and confirmed...don't have the loc handy but it was dead wrong.
I also pulled up the APYU bin ('89 Vette, 6-speed) and TC with the "D" TDF shows it as an automatic. Not good. Hopefully it's fixed in the current TDF version.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Sep 8, 2001 | 01:35 PM
Kevin91Z's Avatar
I think you really need to update your TDF's. $8D is up to version T and $6E is up to version T as well.
http://www.tunercat.com/
But what about my original question. Does the computer care if I have a 5-speed or a 6-speed?
Old Sep 8, 2001 | 03:05 PM
kevinc's Avatar
Car: 1982 Z28
Actually T is outdated now...it was also looking at the same incorrect location. TC has just released a revised TDF for $6E with the correction included.
To the original question, the '165 and '730 ECMs have no sensor input from the manual trans other than VSS so I can't see any means for the ECM to know if you're running 5 or 6 speed.
As long as it's manual, and the ECM knows it's manual, you're in good shape.
-Kevin
1982 Z-28
Old Sep 8, 2001 | 05:23 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
i agree, other than the VSS, theres nothing eles inputing to the ECM.
79 Chevy Malibu Cpe
305 TPI/700-R4,3:50 Posi 9 inch,
Custom Turbocharged,
ported upper and lower intake,
214,224 duration .450I .465E lift
749ECM, modified SyTy software
currently being painted
[This message has been edited by SATURN5 (edited September 08, 2001).]
Old Sep 8, 2001 | 07:03 PM
leirch's Avatar
Like the others have mentioned, other than the VSS the computer won't know nor care. Of course with the different gears and stuff, it is going to throw the load values off when you accelerate, but you may not notice that. It should work just fine providing you can get the VSS to work with your 730 ecm.
Old Sep 8, 2001 | 10:47 PM
Brent's Avatar
FWIW the 747 has a table of ratios that allow the ecm to know by rpm and mph what gear the trans is in. Part of it controls the shift light. It has a definite affect on the IAC and commanded idle speed as you coast down. When the VSS adapter box was way off (high mph) you could watch the rpms fall down in steps as the car came to a stop.
I don't know if your ECM has this....
jhawkeye
May 25, 2022 06:33 PM
RedLeader289
Jan 22, 2016 03:05 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
BBSDesigns
Aug 11, 2015 07:39 PM
Dan383T56
Feb 5, 2001 01:54 AM
