Disable C.A.R.S -skip shift in Y body 8D
Old Oct 4, 2006 | 04:57 AM
SABLT194's Avatar
I've searched the boards, TC and Tunerpro for info relating to disabling CARS or CAGS on a 90 Y body 727 8D. Any info out there???
Old Oct 4, 2006 | 06:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Here are the parameters for a '91:
Code:
; Computer Aided Ratio Selection
; MANUAL XMISSION
L8300:  FCB     120     ; IF COOL GT 50c CK FOR CARS ACTIVE
L8301:  FCB      1      ; RESET SPEED
L8302:  FCB     12      ; ENABLE SPEED
L8303:  FCB     19      ; DISABLE SPEED
L8304:  FCB      48     ; RPM DISABLE
L8305:  FCB      90     ; %TPS FOR DISABLE
L8306:  FCB      76     ; Kpa LOW BARO DISABLE
L8307:  FCB      78     ; Kpa LOW BARO FOR RE ENABLE
IIRC once over a certain throttle position CARS is not invoked. With that I would set the %TPS FOR DISABLE at $305 to 0. Should do it.
If not, then change the coolant (@ $300) to 255, or change both.
RBob.
Old Oct 4, 2006 | 09:46 PM
Z69's Avatar
Z69
The AT bins are set to 255 ($FF) for the temp.
Old Oct 5, 2006 | 04:01 AM
SABLT194's Avatar
Thanks Rbob! That should do it. I'll give it a whirl and see what happens!
Regards,
Steve
Old Oct 7, 2006 | 05:40 PM
SABLT194's Avatar
Worked like a charm! Thanks again
Steve
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
crazynights
Aug 21, 2015 06:53 AM
ezobens
Aug 19, 2015 10:29 PM
dhonda200
Aug 11, 2015 11:50 PM
