is there is good 8F dissassembly thats documented properly ?
Old Oct 5, 2006 | 12:33 AM
Sil's Avatar
Sil
Car: 1993 Pontiac Grand prix
Engine: 2.8/3100
Transmission: 4T60-E
id like to make a complete 8f.xdf and i need a good documented 8f dissasembly.
the one on moates isnt very good, says its 8f but i dont think it is ?
Old Oct 11, 2006 | 01:09 AM
Black91Vette's Avatar
Why do you think that? Is some important stuff missing like eg boost?
Old Oct 11, 2006 | 03:42 AM
Sil's Avatar
Sil
Engine: 2.8/3100
i've allmost finnished it.
i have found the proper address for the 2 constants that were not in the 8f.doc
seems that the 8f.doc is missing chunks around 7xx.
comming along good, just about half way done with the tables, then when i have finnished adding everythign that was in gmpcm, im going to go through the doc, of whats left and try to add the rest in the proper catagories.
it will be "more complete" than gmpcm
and less mistakes
gmpcm had tables cut off, bad eqautions sometimes ect..
Old Oct 13, 2006 | 10:25 PM
Sil's Avatar
Sil
Engine: 2.8/3100
finnished if anyone is intrested in the xdf you can get it off of 60degreev6
- Released 8f.xdf version 1.0 for Tunerpro
Old Oct 13, 2006 | 11:51 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Would like to take a look
Not a member. Can't get to it.
Is it posted on Moates site?
Old Oct 14, 2006 | 12:03 AM
Sil's Avatar
Sil
Engine: 2.8/3100
i havnt emailed him the file yet
but ill upload it here i guess
File Type: zip
Old Oct 14, 2006 | 05:29 PM
Sil's Avatar
Sil
Engine: 2.8/3100
v1.1
fixed hex addressing in flags section
fixed THROTTLE FOLLOWER DECAY RATE VS. MPH (WHEN NOT IN P/N) table
File Type: zip
Old Oct 16, 2006 | 05:35 AM
Great! Your headings and sub headings are very good. I wonder if it is possible to elimiminate those from the "item summary list" though, perhaps something for future Tuner Pro?
The only thing I know about $8F is; 89-90 3.1 V6 PFI turbo on 727 with 27C256. Do you know where to find more info. Eg, one or two knock sensors, SD or MAP etc? I suppose I could figure this out from your XDF and the hac on Moates site but perhaps this is already in print somewhere?
How did you figure out the axles of the main spark advance table? I don't see those in the "calibration" part of the bin so I assumed they are "hard" coded in the assembly program?
Thanks for sharing your work!
Old Oct 16, 2006 | 07:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is SD and 1 knock sensor, DIS ignition. Over on diy-efi is a set of wiring diagrams. Helpful to see what it controlled, how it is set up, and which pins to use.
RBob.
Old Oct 16, 2006 | 07:41 AM
RBob.
Do you mean this place: WebHome < Diy_efi < TWiki
Perhaps the information is not available yet after the move to "TWiki"? Or I'm searching the wrong place?
Old Oct 16, 2006 | 08:47 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
http://www.diy-efi.org/gmecm/ecm_info/1227730/
at the bottom............
/N.
Old Oct 16, 2006 | 09:19 AM
Sil's Avatar
Sil
Engine: 2.8/3100
the link in the above post doesnt mention the 8f code mask but it was used on 727 as it states the 730 is the same ecu just located in the passanger area under the dash behind the glovebox, instead of the engine bay.
you might think about using azrc with the 8f.
i think the 8f was introduced on the 727 but you can use it on the 730 as well. so i believe, im not an 8f guy yet... lol
i plan to boost in the future and made this in preperation.
im a 9396 df guy:P so my knowledge of 8f and 730/727 ecus is still growing.
oh and
i was thinking about grouping some items so you can use the menu in tunerpro to view only certain things, or all things, but i actually forgot, and remembered when i finnished lol
i just wish the tunerpro had colapsable catagories....
Old Oct 16, 2006 | 09:35 AM
That would be really nice
OK, I found the wiring diagrams, thanks!
Old Oct 16, 2006 | 10:49 AM
skwayb's Avatar
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
WOW.. after looking at the 8f XDF... I thought I was looking at $58. Lots of similarity between them. They almost look like the same code......
Old Oct 16, 2006 | 10:31 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
It has filters. I may implement a treeview in a future version that piggybacks off of the user-specified filters. Are the filters as they stand now insufficient?
Old Oct 16, 2006 | 11:07 PM
Sil's Avatar
Sil
Engine: 2.8/3100
not insufficient, just forgot to use them when i was making the 8f lol
with colapsable catagories, you can still see the catagory and to view the contents of that catagory you can click on it and it opens it up.
i dunno user prefference i guess
Old Oct 17, 2006 | 05:17 PM
JP86SS's Avatar
I like them but they do tend to get clunky when used in combinations.
The "focus" can be stuck in the filter selection box on my 98SE laptop and require a kill and restart of TP when Emulating. (Keep forgetting to post that)
The "Item list" as in ScannerPro looks to be the ticket for making your own popular lists. That way you can define sets as needed for specific actions you want to work with. Hopefully that aspect can port over to TP.
Old Oct 17, 2006 | 07:08 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I see the same thing with my WIN98SE setup. The ALDL ads file selector dialog box does the same thing (steals focus). It gets the focus and will not release it after being closed. The ALDL session log message does it too when it is under the monitor window. I do a ctl+alt+del to kill TP. Do you ever get the "not enough memory" when trying to launch other apps while TP is open and you ran some datalogs for a while? On the WinXP box, it just slows the machine down after about 2 hours of going through datalogs.
I like the category functions. They work great I don't see how they could be any better. Is there a way to add double headers to the XDF tables? For example, can the VE table have both a MAP KPA and Vacuum in/hg label at the top of the 3D table?
Old Oct 18, 2006 | 09:59 PM
Mangus's Avatar
Transmission: T5WC
Can you post the repro for the focus issue(s) in the Bug forum over at tunerpo.net? I must not be understanding the problem, as I can't seem to reproduce it.
Old Oct 18, 2006 | 10:06 PM
JP86SS's Avatar
Will do.
I'll do some testing tomorrow night and get the sequence down on how it happens. 2 things to test out andget you some feedback on.
Ended up UNDER the car tonight instead of in it
Old Oct 18, 2006 | 11:12 PM
Sil's Avatar
Sil
Engine: 2.8/3100
sounds like a mem leak in tunerpro ?
Old Nov 9, 2006 | 08:11 PM
mikey7's Avatar
Hi All,
Still new to all this, a few friends and I decided that we were going to inject a four cyl turbo(2.0 ltr.) and started with the 58a in a 1227727(off road )
In short it didn't work (dono why). Found the 8f (turbo 1227727), I would like to know where the :max retard relative to ref
:max advance relative to ref
Also (not like that is enough) where I can get info on the tdf editor(I have a legit program) W ith that info I can get 3 rigs going (one's mine)
PS turbos are more simple to rebuild than program around. Mikey
Hotrodboba400
Dec 10, 2019 07:07 PM
Elephantismo
Feb 13, 2019 12:51 AM
Johnoooooo
Sep 22, 2015 08:55 AM
dimented24x7
Sep 17, 2015 06:58 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
