Super Ram/ LPE 219 cam
Old Oct 2, 2001 | 08:16 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I'm working on a friends' car. It's an 89 Iroc with a 355, Super Ram, AFR 190's and an LPE 219/219 cam, stock 700-R4. It idles when it's cold and in park, but when you drop it in to drive, it stalls unless you keep the r's at about 2000. Instead of having lose money getting a custom chip burnt, I told him to buy the pocket programmer. Problem is we need to move the car out of the driveway due to certain, and understandable, mother issues. It seems that she does not like her new driveway ornament. Can anybody transfer a prom that will enable this car to idle correctly so that we can move it safely.
Old Oct 2, 2001 | 08:32 AM
crucial's Avatar
Why not drive with two feet AT 2000 rpm ? One on the gas and one on the brakes !
1991 Z28
357 4 bolt main block, TrickFlow 23 degree heads, CompCams CS270HR cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, 2500 stall, bullet proof 700R4.
Old Oct 2, 2001 | 10:33 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Well, it would be neither safe nor driveable. Why don't they drive top fuel dragsters on the street?
Old Oct 2, 2001 | 12:10 PM
leirch's Avatar
TPI guy, Toledo huh?
I have about the same setup minus the heads/exhaust.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Oct 2, 2001 | 02:25 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
This is the exact same combo that I'm building... AFR 190, superram, LPE 219/219 cam. I'm very interested in the outcome of this combo
Old Oct 3, 2001 | 08:12 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Yes, well I will let you guys know when it gets moved out of my friendd's driveway. In the meantime, however, I'm looking for a way to make the thing idle decently. Leirch, did you have any erratic idle problems?
Old Oct 3, 2001 | 08:29 AM
leirch's Avatar
TPIGUY,
Yep. I had all kinds of idle problems.. But most of my problems were shortblock problems. I switched over to speed density and that seemed to help out a lot. If you were a little closer I'd bring diacom over and help you diagnose the problems. I'd say if you HAVE to get it out of the way, just baby it gas/brake until you get it where it needs to go. I know, its not safe but sometimes you don't have a choice..
Brendan
Old Oct 3, 2001 | 11:34 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
My '87 IROCZ will run OK with the stock GM chip.
I think that you should check all of your work, and look for vacuum leaks.
Another thing is that the 219/219 cam probably likes more rpm at idle to run more smoothly. Do an idle air adjustment, have the idle speed set to 900 to 1000rpm. Also, you might want to increase your static timing.
When you learn how to program a chip, start off with the ARAP chip.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 3000 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, 24#/hr SVO injectors, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(50psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.27sec @ 103mph on MT ET Streets
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Old Oct 3, 2001 | 01:59 PM
leirch's Avatar
Definatly more timing at idle. Mine is around 20-24d at idle. Seems to like it right there.
Old Oct 4, 2001 | 07:53 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Hey doc, how do you like that ZZ9 cam?
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
masonta
Sep 1, 2015 06:40 PM
