Ribbon cable to memcal
Old Feb 6, 2001 | 09:41 PM
Aaron's 87's Avatar
Who has run a cable between the eprom and memcal to make eprom switches quicker? What kind of cable will shield from interference?
Old Feb 7, 2001 | 05:24 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Aaron's 87:
Who has run a cable between the eprom and memcal to make eprom switches quicker? What kind of cable will shield from interference?</font>
Old Feb 7, 2001 | 05:28 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
On some cars as little as 6"s of ribbon lenght is enough to pick up RFI. I've seen some switcher boxes that use like 18" long ribbons. If things act goody take it out and see if that fixes the problem.
Old Feb 7, 2001 | 07:33 AM
Aaron's 87's Avatar
I haven't done it yet to know if I'll get interference. I was just wondering if it's something that can be done reliably.
Old Oct 5, 2001 | 12:26 PM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
I tried this and it didn't work for crap....Kept shorting the ribbon and it got alittle better but I don't like marginal results...stay away from this your time is spent better elsewhere. Just my $.02
White 89 Corvette....
Open Air box
Relocated MAT
Air foil
160 Stat
Lower Coolant Sensor
13.6 1/4 mile Total Stock
Old Oct 6, 2001 | 12:57 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I also tried this with no luck
I'll probably revisit it later, but I got fed up with it and dropped the idea for now.
Old Oct 6, 2001 | 09:02 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I have a ribbon cable and ZIF. Works fine at a length of like 9". At 18" I was having problems.
There is real potential for a problem. You might want to go really short, quality, or do something different.
Old Oct 7, 2001 | 10:11 AM
Sarkee's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Craig Moates:
There is real potential for a problem. You might want to go really short, quality, or do something different.</font>
Craig -
Have you (or anyone) gotten a harness extension cable (from harness connector to ECU) to work? I've been trying, but I'm afraid my hands shake too much for accurate pinpoint soldering on a donor ECU socket... (I'm looking for a local elect repair shop)...
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
